Carb Question
I have time to make a carb with the NVA set right over to one side and just basically a hole( my multi jet carb will have to wait for a few more days ,,,,,, weeks ) , guessing a 4.5 mm hole for a OS 15 on a 9x5 ?????, are there any RPM's to be gained over the standard NVA in the middle of the venturi hole type carb????, and if so why ,,,,,,
RE: Carb Question
Since fluids/air tend to flow in the center of a round pipe or carb venturi and move slower around the edges, the center would be better. The Webra DynaMix carb has the fuel discharge on the side and has a pseudo accelerator pump to compensate for poor fuel draw.
RE: Carb Question
If you have a spray bar that protrudes into the venturi, the area must be taken into account. That is to say a venturi with radial fuel feed of a given diameter has greater throat area than the same diameter with a spray bar in it. Venturi design is simple and a fuel passage in the side of the venturi itself is perfectly acceptable, and is not a detriment, unless the overall design is poor.
RE: Carb Question
I found that a spray jet, entering the venturi from one side only, gives best performance when the jet ends exactly in the venturi center. A spray bar is much less critical.
RE: Carb Question
ORIGINAL: 123Cat I have time to make a carb with the NVA set right over to one side and just basically a hole( my multi jet carb will have to wait for a few more days ,,,,,, weeks ) , guessing a 4.5 mm hole for a OS 15 on a 9x5 ?????, are there any RPM's to be gained over the standard NVA in the middle of the venturi hole type carb????, and if so why ,,,,,, http://www.clacro.de/ Go to 'design/ venturis and venturi size.' Its worth a read and I agree with Pé about the use of a fuel spigot in all cases except outright power, there the peripheral type of venturi rules. |
RE: Carb Question
I was going to comment on Greg's comment, Holly did that very thing with the 500/650 two barrel carb, the 650 had no spray bar the fuel discharge holes are around the periphery of the venturi. I think Enya carbs have the tupe of discharge jet Pe' and I referred to. I'll check
| All times are GMT -8. The time now is 11:48 PM. |
