Nothing to do with Silver Swallows engines
1 Attachment(s)
These two engines have come into my hands from separate sources. Both are new unrun Super Tigre G40 racing engines.
The glow is in c/l form with a big venturi hole which would necessitate running on crankcase pressure or a bladder. The second is very interesting because it has a very nicely made two piece diesel head. The engine head screws and the ones for the 2-piece head are not fitted right now. I have the former but need to get some M2 screws for the latter. Then I can run the engine. Ray |
RE: Nothing to do with Silver Swallows engines
Very nice Ray, do you have a use for the big diesel?
The engine has an r/c throttle and may have been intended for some form of r/c club Pylon Racing.
The G40 has been around for decades in c/l form but is hardly cutting edge technology in PR. The conversion could date from the early 1990's. http://images.rcuniverse.com/forum/u...40/Ag91433.jpg The two piece head has been created from the original glow head. The comp screw is a spare Taipan series 13 1/4" x 32 tpi. http://images.rcuniverse.com/forum/u...40/Ic83525.jpg Right now the contra piston sits against the top rim of the central hole. It's inserted from below. I'd imagine that an important advantage of a two piece head is that it's easier to machine and perhaps lap the CP and the head. http://images.rcuniverse.com/forum/u...40/Vh56193.jpg The CP is machined from Aluminium alloy and is a very tight fot in the head. Perhaps it's shrunk in without an o-ring. http://images.rcuniverse.com/forum/u...40/Fw28555.jpg Regrettably there's no real practical use for a big diesel like this in c/l flying. It's always going to be less powerful than when in glow configuration and the major advantage of more economy doesn't help. Ray |
Very unusal head is it custom or factory?? martin
I guess you's call it "custom". It's made from the original head. It was possibly made by the well know Australian tuner, Stan Pilgrim. Stan is one of the "Motor Boys" a group that will be well known to those more interested in the technical side of model engine construction. I believe that Stan may have originated the notion of this type of 2-piece head. Gordon Burford copied this idea in the batch of 200 (or so) Goldhead 15 FIRE diesels he produced in the 70's.
Ray PS Actually it may have been a batch of 100 (or so) Goldhead diesels |
Ray,
If there's no one up your way with M2 screws, the Nut House in Parramatta will have them. Regrettably I'm out otherwise you could have them on Sunday [:o][&o] G On second thought, there's a nut shop closer to me. I can get some tomorrow if you want. How many? How long? G |
| All times are GMT -8. The time now is 01:22 AM. |
