SuperTigre .90 conversion
1 Attachment(s)
This is the carb I use on the ST .90 conversion. It is a .61 size carb with the thin spray bar. Maybe someone can enlighten me because it may be the stock carb. Thanks, Dave
Originally Posted by Hobbsy
(Post 11814711)
My G51 has the same carb your .90 has except the spraybar was round originally. The choke diameter should be about 8.9mm. |
Thanks Q, I have a bunch of ST carbs and lose track of what is what. I was trying to answer a PM but couldn't send a picture so I posted the picture here.
(Post 11814802)
If you (or anyone else) ever come up with some ST carbs you don't want or need, let me know. I wish they made one with a .627" neck. |
Hi Hobbsy,
Please keep us posted on this one! I just got a Davis head for my S90K, and have to do all the setup work. I have a bunch of G60s, so may have my carb issue handled. Jeff |
So, it turns out that I wound up with 3 carbs when I got my 2 ST S90Ks. Two of them had throats that measured 8.8mm, and 1 measured 7.3mm, though it wouldn't fit the inlet on the engine. But, the throttle drums are all the same diameter, so I made a quick swap, and I should be all good to go now!
| All times are GMT -8. The time now is 04:52 AM. |
