RCU Forums
-   Everything Diesel (https://www.rcuniverse.com/forum/everything-diesel-87/)
-   -   McCoy 09 (https://www.rcuniverse.com/forum/everything-diesel-87/11688440-mccoy-09-a.html)
Vekenti 03-10-2021 12:08 PM
McCoy 09
Hello.
I've been interested in diesel ever since I started flying RC, about 2 years now. The sound of a diesel is very unique, and I finally found a decent deal on an engine.
The engine is a McCoy 09. It has been modded with an OS Pet throttle Carb. From pictures it seems like a messy modification. I haven't received the engine yet, and from ebay it's either going to be a win or lose. Worst case I'm out $50 and have a drawer queen :). I'll have to update this thread when I get it and hopefully get it running!
Was wondering if anyone knew how to disassemble this engine? I can't seem to find much info on it which is surprising seeing how popular they are. I like to completely disassemble every used engine I buy to completely clean and oil the internals.
In my part of florida seems like there isn't any john deere dealerships. I searched every single store that sells starting fluid and finally found a starting fluid that contains between 30-50% ether. This should be adequate for diesel fuel correct? What mix should I use for this little mccoy? I prefer longevity over power of course, and smell doesn't bother me. Hell my car already reeks of gasoline.
qazimoto 03-14-2021 03:05 AM
Originally Posted by Vekenti (Post 12667891)
Hello.
Possibly not a good place to start a journey into the model diesel engine experience. A new PAW 09 would be my choice. The engine is likely to be at least +65 Y/O, and it has a rather vulnerable O-ring in the contra piston. I have a few of the OK and McCoy small diesels, and I'm happy with them. However they are a bit of a nightmare to dissemble at their age, and you will need a "strap-wrench" (try google). I ruined a cylinder trying to disassemble a 70 y/o OK diesel which had a very soft exhaust pillars. Rather I'd soak it in a jar of Kero instead, and then oil up the O-ring by squirting Auto Transmission Fluid into the head via the exhaust. If it will hold compression (after washing the ATF out) then try to start it by all means. Have a look at the attached link for more information. Some people here have had success with the John Deer fluid, but I'd be very wary of stuff with less Ether. Remember 50% Ether means another 50% of some other hydro-carbon, which may not like running in a diesel. They run best with genuine solvent grade Di-Ethyl-Ether. Anyway good luck!
The McCoy Diesels (Adrian Duncan review)
Vekenti 03-14-2021 11:42 AM
I have received the engine and I figured out that the engine head (the part they call the muff I guess?) screws off. I used 2 soft pieces of balsa and a bench vise and just enough pressure to hold on to the head while I screwed it off. No damage to the coating, although I can see where this method could cause the fins to break or worse damage, I didn't have a strap wrench around. The piston and cylinder looked really clean. Very light carbon build-up on the top of the piston. The crankshaft, case, and head all look really clean and the red is still nice and bright red. The contra piston is a little stiff but moves smoothly, and the O-ring looks like it was recently replaced. I'm not sure how well compression shows the age of diesels, but completely removing the compression screw the engine still has a nice pop to it.
As for the fuel. The starting fluid I chose has 40-70% Heptane, 30-50% Ethyl Ether, and 5-10% Carbon Dioxide. I have been told that Heptane can be treated as Kerosene in the fuel mix, and should be safe. I plan on starting off with 38% Kero, 30% Castor, 30% Ether, and 2% Cetane Improver. Too little Ether will cause issues in the engine, so would it be a good idea to include a little more Ether in the mix?
I'm not really looking for power out of this engine even though I heard these McCoys are real powerhouses. This is an engine to learn on to see what Diesel is all about. I plan on dropping it into my 15 size cub. Should pull it along just fine I think. If not I will build a new model based around just this engine.
qazimoto 03-14-2021 01:59 PM
OK sounds like you have the deal under control. Certainly too little Ether or lack of a DII will cause problems. I don't know if I'd consider the McCoy as a powerhouse. Diesels have moved on a lot since 1954, and there's a lot of McCoy 09's sitting around with broken crankpins :-). I've attached some pics of my homemade strap spanner. Good luck.
https://cimg5.ibsrv.net/gimg/www.rcu...ee47574097.jpg
https://cimg6.ibsrv.net/gimg/www.rcu...f2968a5a49.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...bffe1a828e.jpg
https://cimg9.ibsrv.net/gimg/www.rcu...5058176cc2.jpg
https://cimg2.ibsrv.net/gimg/www.rcu...9303ab5afc.jpg
Dan Vincent 05-22-2021 01:53 AM
An OK Cub .14 cylinder removal tool fits a Mc coy .09 diesel perfectly.
Usually a little heat helps break a muff loose.
https://cimg3.ibsrv.net/gimg/www.rcu...a5c8808679.jpg
ffkiwi 06-09-2021 11:01 PM
In your shoes I would try and find a better source of easy start ether-with a possible level of only 30% in the can before you extract it-you would end up with a fuel containing only about 20% ether-taking the lowest end of the stated ether range-conversely if around 55% ether before you start then this wouldn't reflect a problem in the final fuel mix....the problem is-you have no way of finding out how much ether is in the easy start mix in that particular can-unless you have easy access to a very well equipped analytical chemistry laboratory...! This is why I DON'T recommend using such products unless you have absolutely no alternative-and if you don't-then try and get one of the top line products such as John Deere brand which is usually 80% ether or better.....at this point of your experience level the last thing you need is a sub par fuel mix-diesels can be tricky enough for new users with everything bang on in terms of settings and fuel.
I do agree though-that in your case you can factor the heptane content as the kerosene component of the fuel. Ideally-try and get an experienced diesel operator to show you how to handle a diesel-it is not entirely intuitive until you get the knack.
ChrisM
'ffkiwi'
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
