RCU Forums
-   Everything Diesel (https://www.rcuniverse.com/forum/everything-diesel-87/)
-   -   Stuck Ring (https://www.rcuniverse.com/forum/everything-diesel-87/2017833-stuck-ring.html)
FrancisPerson 07-23-2004 07:01 PM
Stuck Ring
I have a FOX Eagle III that I run as a Diesel. Last week I flew my plane fine, except that on the last flight it sagged and quit like it was suddenly very over compressed?? I had changed nothing and the exhaust was not terribly dark. Today the engine would not start? It would run briefly with more priming flips that usual and ONE ADDITIONAL turn of compression! Tonight I took the engine apart and found the ring is frozen in its grove with carbon. What can I soak the piston in to fix this?
Francis
AMB 07-23-2004 07:40 PM
RE: Stuck Ring
Francis soak it in jar with either diesel fuel or lacquer thinner or xylol for a day it should soften up the carbon so you can clean it off
capin 07-23-2004 09:17 PM
RE: Stuck Ring
love that acetone or castrol super clean to get rid of carbon build up. Brian
