information and help please.......
:([img][/
hiya.... can anyone help me please? I have a small diesel model aircraft engine that has Allbon written on the side..which is about the size of a DC dart..maybe a bit smaller..would estimate to be about 0.5 or 0.8 cc..which has green cylinder fins...could anyone give me any information on it please...i.e what it is etc..... Also it has the compression screw missing...would anyone know what shape this would be..i.e. 'T' bar..or 'L' shaped lever..... most appreciated... allen |
RE: information and help please.......
Albon Dart... .5cc, supposed to have a T style comp adjuster
Trying to find a photo I know I have one... AJC |
1 Attachment(s)
Here it is!
thank you so much for letting me know what it is..........now i know what type of bar to look for.........
will try to look up some info on it now.. once again...many thanks for your help allen |
you might get lucky check with Paul at just Engines on your side of the pond a PAW compression screw MAY fit if not find a socket head
screw of the same thread REGARDLESS OF WHICH WORKS MAKE SURE YOU DO NOT TURN IN TOO FAR THAT THE CONTRA PISTON STRIKES THE HEAD you can check this by cranking down the screw and turn the engine gently by hand as you turn it in when and if you get contact back it off and make sure you do not go that low again If you go the socket screw bit round the end of the screw si it is not a sharp contact |
HIYA...
THANKS SO MUCH FOR THAT..WILL CERTAINLY GIVE PAUL A TRY........ ALSO THANKS FOR THE ADVICE..VERY MUCH APPRECIATED...WILL TAKE HEED... ANY MORE INFO WILL BE GRAETLY APPRECIATED.. MANY THANKS.. ALLEN |
| All times are GMT -8. The time now is 08:49 AM. |
