RCU Forums
-   Exceed RC Support - Helicopter (https://www.rcuniverse.com/forum/exceed-rc-support-helicopter-473/)
-   -   eagle 50 motor (https://www.rcuniverse.com/forum/exceed-rc-support-helicopter-473/7433216-eagle-50-motor.html)
kolls 04-28-2008 09:49 PM
eagle 50 motor
okey, my eagle 50 motor burnt out for the second time, so i went to the lhs and got another 370sd motor and now it doesnt have enough head speed to take off, so what the difference, one motor i got from exceed was 9t the second was 10t.
yadac123 04-30-2008 11:22 PM
RE: eagle 50 motor
You have to use the same pinon gear that originally from the eagle 50. Swap the pinion gears.
Andy
cflytrap 06-27-2008 12:16 AM
RE: eagle 50 motor
I had tried a Eflite 370SD for BCP replacement motor from my LHS while I waited for a replacement from Exceed. It had an 8 tooth pinion. 8 tooth pinion on a 370sd motor meshed to a Eagle 50 main gear doesnt produce enough headspeed to fly. No matter what you do to the pitch and throttle curves, it will only hover at best, and you will probably burn up the motor trying to figure it out. The Exceed motors have a 9 tooth pinion on them and that makes all the difference in the world.
