WK0701 RX AND TX SETUP
I just received my new tx (wk-701). I already have the rx, but the question is - how do you set it up?? It is NOTHING like the original rx on my Raptor G2. What hooks into the battery slot on the rx? I tried to hook different configs up, but nothing happens. The servos don't even move and the gyro does not even twitch!!!! Battery is fully charged, and i set the DIP switches per earlier posts. What could possibly be the problem?????[&o]
RE: WK0701 RX AND TX SETUP
ok did you get the speed controller from us? what's your order number I can mail you one.
if you want to test the receiver and transmitter then simply plug a 6V battery into the battery slot. You'll need a speed controller for the system. http://www.xheli.com/50brspco.html Trottle to speed controller. alieron to the servo that makes the swash tip left and right elevator to the servo that makes the swash tip front and back rudder to gyro gear not used aux 1 to the pitch servo aux2 to the sense wire on the gyro Andy |
The ESC is a Raiden 30A ESC. I think I ordered it from RaidenTech, or it could have been Xheli - nevertheless, it's been some time ago that I ordered it along with the brushless motor. The brushless motor is from ExceedRC. I will try the 6V battery and see if the rx works. If not, I've already obtained an RMA from ExceedRC and I'll be shipping everything back.
Andy |
| All times are GMT -8. The time now is 10:07 PM. |
