I want to upgrade my heli
I bought the PE edition of the G2 and the rotor head is not the best, I can't get it to hold. When I throttle up the rotor blades go wild and when i throttle down the pitch changes so drastic I have ruined two tail booms. I was looking at new CNC rotor heads and would like to put on the Lightening CNC aluminum Tri blade and wondering if it works good? If not could I use the zoom shotgun 3dx 400 CNC rotor head. IF these don't work could someone please give me some ideas? Thanks
RE: I want to upgrade my heli
sorry G2 are meant for tri-blades rotor head. You can get the upgrade parts 81 to 87.
Andy |
Hi Andy...
I have the receiver (WK-701) and the transmitter (WK-0701) from my old Raptor G2 (been crashed) ... now I want to use it for my new EXI-450 .... Do I need to reset any thing for the transmitter and the receiver ? if yes... what should i do ??? Thanks |
That will not work because your pitch on the G2 is controlled by single servo and this pitch on the EXI 450 is controlled by 3 servos.
Andy |
Thanks Andy.
So, you meant that i have to buy new radio system ? |
by the way, I talked to the guy ( tech. support from Xheli) he said yes, i can use it ... as long as they are the same radio system...
Hi Andy,
my EXI-450 is ready.... but i have a problem... when i throtle-up, the motor doesn't spin ... but when i turn the switch to 3D mode ... the motor spins backward... do you have any idea ?... |
Switch any two wire connections btwn your motor and ESC. That should spin your motor in the right direction.
the problem your have is your listening to someone from xheli.
they`ll tell you anything so you`ll buy more faulty crap from them its a revolveing door with xheli. they just keep shipping used and faulty parts out daily |
make sure your setting on the trottle is correct low stick is 0% throttle and high stick is 100%. Make sure your throttle channel is not reversed.
Andy |
