Default settings for transmitter
I have the Exceed RC G2 with the WK-0701 PCM transmitter. I tried messing with some of the adjustments and now I believe they are all screwed up. I would like to know if there is a site to get the factory default settings for this transmitter or does anyone know what they are? i still fly jjust fine but now it seems I have less power at full throttle I can hover only about 4 ft off the ground. Also, I might add. When I followed the directions for changing the throttle curve, the color on the transmitter was not 'Blue' like it was supposed to be. At least according to the instruction manual that came with the heli. Thanks for anyones input Tim</p> |
RE: Default settings for transmitter
2,4,6,7 are ON rest are all OFF. Do not adjust the setting on the throttle curve unless you changed to a brushless system.
Andy |
Do I need to somehow 'zero' the transmitter before resetting the switches. Since I changed the throttle and pitch adjustments, do they need to be set to defaults or will this automaticallly reset when I follow your above reply?
Thanks Tim |
Unfortunately only walkera has the default setting to their radios. You'll need to setup your heli base on the setting you already have in the radio.
Andy |
Andy, are those the same settings for the G2 SE?
Mine are factory set at 2, 4, 6. The manual states 4, 8 as the defaults. |
try this
2,4,8 ON rest are all OFF Yes SE would be the same. Andy |
ORIGINAL: yadac123 try this 2,4,8 ON rest are all OFF Yes SE would be the same. Andy |
| All times are GMT -8. The time now is 03:49 PM. |
