EXCEED MADHAWK 300 AIRWOLF???
HI ALL I would like to know if this is a good stable heli for a newbie to helis. I have the blade msr and can hover pretty good N, E, S, and West . And also can fly flat slow speed forward circles left and right...every now and then I will hit a wall or door knob:D But low and behold I was on the rc motorcycle section on RCU and I saw an add for Xheli.com. That was my first time hearing about them, after viewing their site I fell in love with that madhawk 300 airwolf. I was at the hobbystore thee other day and ask them did they have anything that was fixed pitch like the Blade msr but in a bigger size...and they said NOPE. But as I said low and behold I came across xheli.com, so tell me what you guys think will that madhawk 300 airwolf perform like the blade msr fixed pitch mini heli or better??? Or shall I gone ahead and get that rc TTiger motorcycle (I'm just trying new stuff out:D Thanks for your reply's
RE: EXCEED MADHAWK 300 AIRWOLF???
Yes the madhawk 300 is a perfect helicopter if you want to give yourself a bit more challenge. The rotor head is a hybrid of fix pitch and coxial so you get the pros of both heli.
Andy |
ORIGINAL: yadac123 Yes the madhawk 300 is a perfect helicopter if you want to give yourself a bit more challenge. The rotor head is a hybrid of fix pitch and coxial so you get the pros of both heli. Andy |
Oh and what wind speeds can this heli fly in. Thanks again :eek:
Hi is this walkera model the exact same chopper as the exceed madhawk airwolf 300 http://www.xheli.com/walkera-hybrid-...elicopter.html
Because if it is the walkera model says it is 21 inches long and the exceed model is only 18 inches long http://www.xheli.com/50h28-madhawk300-red.html Also do they have the same style of rotory head, it says the walkera head is cnc....is the exceed rotory head on the madhawk 300 made of aluminum parts because from the pic's they look like black plastic. Thanks please let me know so that I can place my order I tried calling you guy's but the phones are always busy [:@] Please let me know the correct size of each because I want to order the longest one but I like the red and white exceed madhawk 300 but if the walker is almost 4 inches longer then I will get the walker cb180 airwolf. Thanks again;) |
both models share the same parts just the color is different. I'm looking at the description and it doesn't say 21 inches so where did you get that? Yes both model are aluminum head not plastic.
http://www.xheli.com/walkera-hybrid-...elicopter.html descriptiuon says 18 inches. http://www.xheli.com/50h28-madhawk300-red.html clearly mentioned "New Precise CNC-machined metal rotor head provides more operation accuracy" ??? Andy |
ORIGINAL: yadac123 both models share the same parts just the color is different. I'm looking at the description and it doesn't say 21 inches so where did you get that? Andy THE PROOF http://www.youtube.com/watch?v=p3blNH2bNEw[sm=wink_smile.gif] |
ok I see. I do see that the web has been changed when someone brought it up on youtube. Thanks
Andy |
ORIGINAL: yadac123 ok I see. I do see that the web has been changed when someone brought it up on youtube. Thanks Andy |
1 Attachment(s)
ORIGINAL: aluminum crusher ORIGINAL: yadac123 ok I see. I do see that the web has been changed when someone brought it up on youtube. Thanks Andy Some step by step repair instructions would be nice. http://www.rcuniverse.com/forum/js/f.../msn/49_49.gif |
ORIGINAL: Eddie48 ORIGINAL: aluminum crusher ORIGINAL: yadac123 ok I see. I do see that the web has been changed when someone brought it up on youtube. Thanks Andy Some step by step repair instructions would be nice. [img][/img] |
ok if you guy need to hold the rudder a in single direction to make the tail hold that means your RX's proportional gain got offset. To fix this look for a pot on the receiver and fine tune it.
the top dial is the sensitive of the gyro, how well you want the gyro to hold and I don't think this dial need to be adjusted. the bottom dial is the one you want to play with. If you have to hold rudder left to stabilize the tail, the fine tune that dial right, clockwise, to offset it. Do it in small increments. Try this until you get it right. no matter how much you try you can only get it fairly stable and it will never be perfect. Andy |
ORIGINAL: yadac123 ok if you guy need to hold the rudder a in single direction to make the tail hold that means your RX's proportional gain got offset. To fix this look for a pot on the receiver and fine tune it. the top dial is the sensitive of the gyro, how well you want the gyro to hold and I don't think this dial need to be adjusted. the bottom dial is the one you want to play with. If you have to hold rudder left to stabilize the tail, the fine tune that dial right, clockwise, to offset it. Do it in small increments. Try this until you get it right. no matter how much you try you can only get it fairly stable and it will never be perfect. Andy |
what I did was I had to use brute force to take it off, if the gear come off it's ok because once the tail rotor is off I insert the gear back on after.
Andy |
My main rotor blades are not turning, everything else works except the main rotor blades and the tail blade isn't turning either. I get a slow blinking red light on the heli's receiver because I turned the transmitter on then the receiver, which is thecorrect way. The main rotor and tail blades still do not turn. I'm getting a new receiver, disregardwhat I wroteabove.
One more question...
Are the main blades supposed to be close to tight or loose so they just flop around freely? http://www.rcuniverse.com/forum/js/f.../msn/49_49.gif - Ed |
I decided this is the next one for me. I like the looks a lot and being a fixed pitch/4 channel/single rotor, it will be the next step up from coaxial. I'm opting for the Walkera version for the aluminum head, CNC blade holders and swash.
I'll see how this goes then move to my HoneyBee King and Belt-CP 6 channel. So how's your MadHawks doing? |
ORIGINAL: Eddie48 One more question... Are the main blades supposed to be close to tight or loose so they just flop around freely? [img][/img] - Ed Tighten them up snug then tip the heli sideways with rotors parallel to the heli. Loosen the screw slowly, and I mean slowly, until the blade drops on it's own. This is where you want it. Reason to have them swing free is when you hit something they will give instead of snap or ruin your gears. |
ORIGINAL: Eddie48 One more question... Are the main blades supposed to be close to tight or loose so they just flop around freely? [img][/img] - Ed |
ORIGINAL: aluminum crusher ORIGINAL: Eddie48 One more question... Are the main blades supposed to be close to tight or loose so they just flop around freely? [img][/img] - Ed http://www.youtube.com/watch?v=JLxkkkuqUYg |
[/quote]
Leave them snug but loose= very free movement. I decided to keep mine after taking off the fuselage and re-centering the servo's and changing the ball end links to the outter hole it makes a big difference in movement. I'm trying to up load a video on youtube but it will not upload, it's only 633mb . I even convert it to mpeg for HD and it still will not upload what gives. And for the tail blades heat it up with a hair dryer or heat gun and then pull it off or cut it with a dremel but do not cut the tail shaft. I hope to get this video up my youtube name is BIGGBULLxxx. So keep an eye out for it. [/quote] I already got the tail rotor off and put a new one on. I'll keep the blades snug but loose with free movement. I did have a fewgood outdoorflights with the helicopter. As soon as I get the heli working again I'll upload a few videos to youtube. I liked your video aluminum crusher... http://www.rcuniverse.com/forum/js/f.../msn/49_49.gif You have some nice helicopters, I also have a blade CX2, maybe I'll upload an old video of the CX2. - Ed |
ORIGINAL: Eddie48 [/quote] I already got the tail rotor off and put a new one on. I'll keep the blades snug but loose with free movement. I did have a few good outdoor flights with the helicopter. As soon as I get the heli working again I'll upload a few videos to youtube. I liked your video aluminum crusher... [img][/img] You have some nice helicopters, I also have a blade CX2, maybe I'll upload an old video of the CX2. - Ed [/quote] Thanks.... I will put up a better one as my flying skills become much better along with the weather, it's cold outside[&:] Yes go ahead and put up your video and don't forget to rate my video. Thanks |
[/quote]
Thanks.... I will put up a better one as my flying skills become much better along with the weather, it's cold outside[&:] Yes go ahead and put up your video and don't forget to rate my video. Thanks [/quote] Here's a link to my blade CX2 video... [youtube]http://www.youtube.com/watch?v=_2Te3NUiJLU[/youtube] |
ORIGINAL: Eddie48 [/quote] Here's a link to my blade CX2 video... [youtube]http://www.youtube.com/watch?v=_2Te3NUiJLU[/youtube] [/quote] OK GREAT VIDEO THANKS;) |
there is nothing wrong with the receiver you have. You need to connect the battery to the receiver first and then turn ON the radio. Before you turn ON the radio you need to have left joystick down and the speed trim down. Then move the right joystick in a circular motion to trigger the binding procedure. The main blade suppose to be snug on the main blade holder.
Andy ORIGINAL: Eddie48 My main rotor blades are not turning, everything else works except the main rotor blades and the tail blade isn't turning either. I get a slow blinking red light on the heli's receiver because I turned the transmitter on then the receiver, which is the correct way. The main rotor and tail blades still do not turn. I'm getting a new receiver, disregard what I wrote above. |
