Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
1/8Th Alpha Blue EP Mad Warrior Racing Edition Truggy Ready to Run RTR Brushless Moto
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 09-18-2018, 01:12 PM
yadac123
Default 1/8Th Alpha Blue EP Mad Warrior Racing Edition Truggy Ready to Run RTR Brushless Moto
https://www.nitrorcx.com/52c75-re-ma...brushless.html
The new generation of Exceed Rc's 1/8th scale MadWarrior has finally arrived. The new MadWarrior EP Racing Edition is Exceed's electric-powered adaptation of the fan favorite MadWarrior. This new variation comes fully equipped with a revamped brushless powertrain and an improved chassis and suspension design. The focus of this new design is entirely on increasing performance and durability to handle the most extreme racing conditions.
The new MadWarrior EP Racing Edition features a rugged 540L brushless motor rated at 2150kv and a 100-amp XeRun Programmable ESC. The truggy is powered by dual 7.4v 3300mAh LiPo batteries wired in series to generate a peak 14.8v. The MadWarrior EP Racing Edition is equipped with an anodized aluminum chassis, shock towers, top plate and chassis braces which adds to this truggy's clean look and feel. The MadWarrior EP is outfitted with CVD front axles and 16mm big-bore aluminum shocks with threaded shock collars. This awesome new platform rides on 5? tires glued to a 17mm hex wheel adding to the sleek design of the chassis. The MadWarrior EP Racing Edition is fully stocked with all these upgrades to handle the pressures of high-level competitive racing.
This new variant of the MadWarrior enjoys a huge increase in performance and reliability and is sure to be a top contender in the Truggy class.
2 Channel 2.4ghz Exceed RC Radio System
540L (36x65mm) 2150kv Sensorless Brushless Motor
XeRun 100A-R Programmable ESC 2-4S LiPo 3A @ 5.75v
ND1009 Metal Geared Steering Servo
Front CVD Axles
4mm thick aluminum front & rear shock towers
3mm thick aluminum chassis plate
Aluminum chassis braces
Aluminum top plate
16mm Big Bore Shocks w/ adjustable threaded collars
Aluminum steering hub
Hardened & Coated Steel Gears
Multi-piece Anti-Sway Bars
Fully Sealed Ball Bearing Set
Two 7.4v Li-Po 3300mah 20C Cont / 40C Burst batteries included
This item Does NOT come with Charger
Motor: 540L Brushless Motor
Bearing: Ball Bearing
Length : 20.08 inches (510mm)
Width: 16.92 inches (430mm)
Height : 8.27 inches (210mm)
Wheelbase: 14.88 inches (378mm)
Gear Ratio: 1:15.8
Batteries: 2 x Li-po 7.4V 3300mAh Cont. 20C/ Burst 40C Batteries
ESC: 100A Brushless ESC
Radio: 2.4Ghz Pistol Remote Control
