Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
Dimension Professional 3 Axis Modular Gimbal
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 10-09-2018, 12:35 PM
yadac123
Default Dimension Professional 3 Axis Modular Gimbal
https://www.nitrorcx.com/08p-metal-3x-gimbal.html
The Dimension gimbal is designed for handheld or aircraft/vehicle use. The gimbal crane features three motorized control units that allows pitch, yaw, and roll stabilization. Cameras attach by securing simple thumbscrews without any tools, and full setup can be achieved within a quick timeframe. The unit is designed primarily for compact cameras such as the GoPro Hero 3, 3+, 4, or other similar sized compatible camera units. The gimbal crane will have a set of rubber dampers that are included to tune out vibration depending on your mounting application. These dampers reduce vibration and eliminate shakiness during filming.
Specifications:
Working Voltage: 12-18v
Max Pitch Range: +45 degrees / -90 degrees (control speed 25 degrees/second)
Roll: +45 degrees / -45 degrees
Max Yaw Range: +160 degrees / -160 degrees
Weight: 220g
Height: 92mm
