Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
1/10 2.4Ghz Exceed RC Storm Red Electric SunFire RTR Off Road Buggy Storm Red RC Remo
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 12-06-2018, 02:12 PM
yadac123
Default 1/10 2.4Ghz Exceed RC Storm Red Electric SunFire RTR Off Road Buggy Storm Red RC Remo
https://www.nitrorcx.com/51c802-stormred-24ghz.html
1/10 Off Road Electric Buggy (2.4GHz Ready-to-Run)
Now with 2.4GHz, the most popular 1/10 4 wheel drive electric power off-road buggy in the world just got better! At each evolutionary step, the SunFire has been improved upon to keep it at the peak of the RC off-road buggy field. So how do you make an SunFire better? Extra speed, extra adjustability, extra toughness! The new SunFire is packed with features that have been suggested by SunFire owners: More room for the electronics, easier access to the differentials and more suspension adjustability. The result is the best SunFire ever.
The heart of the SunFire line has always been a RC540 with reliable and consistent power for tough off-road driving.
Even the storm cellar can't stop the Sunfire Buggy!! Exceed's New Electric Buggy hits the competition with the force of an F-5!!! The RC 540 High Torque motor produces outstanding power!!! Did someone say "JUMPS"?........How high do you want to go? The long travel suspension and oil-filled shocks help absorb just about anything you can drive it over. The linear motor driven brakes ensure "on-a-dime" stopping power, even at these speeds!!!........but who wants to stop when you are having this much fun?
RTR C factory assembled with installed motor and radio gear makes getting started easy
The 2.5mm lightweight aluminum alloy chassis provides excellent performance and durability
New lightweight suspension arms deliver quick suspension response and reduce the critical sprung weight and overall weight of the car
Oil filled shocks with firm tuned springs keep the wheels on the ground
The SunFire will be available "Ready-To-Run" making it the highest on-road performance 4-wheel drive Electric Power racing car available to everybody
Completely preassembled with high quality radio gear, painted, trimmed and ready to roll
The new RC540 motor provides reliable and consistent power for high performance on-road driving
Excellent differential system design provides quick access to the front or rear differential by removing only few screws. You can now access the front and rear differential for easy maintenance
High capacity battery provides long run times
The high quality AM transmitter and receiver work together to let you precisely control your car.
Length:
400 MM 15.7 inch.
Width:
250 MM 9.8 inch.
Height:
160 MM 6.3 inch.
Wheelbase:
275 MM 10.8 inch.
Ground Clearance:
26 MM 1.02 inch.
Diameter Of Wheel:
86*32 MM (F) 86*40 MM (R)
Battery:
7.2V 1800mAh Ni-Mh
Motor:
RC 540
Gear Ratio:
8.038:1
Contents: The new Exceed-Rc SunFire EP - 1/10 Scale Fully Ready to Run Electric Buggy includes just about everything you need in the box. Battery, Charger, AM Radio is included. Just add Qty 8 AA batteries in the remote and you are ready to go.
2.4Ghz Pistol Radio Transmitter
Powerful RC540 Motor;
Aluminum Centre Transmission Shaft
Front/Rear Differential Gear;
Suspension Arms With Adjustable Width;
Four Wheel Driver System;
Powerful Electronic Speed Control Provides Easy And Quick Response;
Solid Aluminum Upper Deck;
Durable And Anti-skid Wheel Tyres;
7.2V 1800mAh Ni-MH Battery Power;
Engine: RC540 Stock
Transmission: Single speed with Reverse
Gear Ratio: 8.038:1
Drive System: Four Wheel Drive
Radio System: Two Channel A.M.
Length: 400mm
Front Track: 215mm
Rear Track: 205mm
Overall Height: 160mm
Wheelbase: 275mm
Front Shock Length: 85mm
Rear Shock Length: 85mm
Front Tires: Block Tread
Rear Tires: Block Tread
Wheel Width: 32mm (F) - 40mm (R)
Wheel Diameter: 86mm
Brake Type: Linear Motor Driven
Suspension Type: Plastic bodied oil filled shocks
What's Needed: 8 AA Batteries...That's it.
