Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
Exceed RC 1/18 Red Mad Pulse Brushless Drift Car Ready to Run RC Remote Control Radio
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 12-17-2018, 02:12 PM
yadac123
Default Exceed RC 1/18 Red Mad Pulse Brushless Drift Car Ready to Run RC Remote Control Radio
https://www.nitrorcx.com/52c96-madpu...less-nimh.html
The 1/18 Scale Exceed RC Mad Pulse drift allows you to get your racing and drifting fix anywhere. Its micro size and performance features make it an awesome drifting machine for everyone. With features and components such as a 4 wheel drive transmission, coil shocks, fully adjustable suspension, and a high performance electronic system, this car is ready for some serious action.
This car is completely ready to run with the included 2.4ghz radio system with brushless 4000kv motor and brushless electronic speed controller installed. Itís also powered by a 6v 1000mah ni-mh battery pack. The 2.4ghz radio system allows for precise control of the vehicle. You also won't have to worry about "the other guy's" radio and if there will be radio interference. The 2.4ghz frequency jumping system allows this 2.4ghz radio system to stay connected and avoids interference which may cause you to loose connection or control.
A 6v Ni-Mh battery and charger enhances the power delivery and runtime allowing the vehicle to run faster, harder, and longer. It's a new era for radio control and this mad pulse car is just that. The only drawback is the difficulty in choosing which awesome paint color to go with.
All that is needed to be ready to run, is to charge the battery and youíre ready to hit the drift course! The little size means you can make a drift course right in your living room!
Features:
-Full time 4WD system
-coil shocks
-Fully adjustable independent suspension
-2.4ghz radio system
-6V 1000mAh Ni-Mh Battery
-Ni-Mh Charger
-4000KV brushless system
Specs:
Length: 240mm
Width: 110mm
Wheelbase: 150mm
Height: 75mm
Ground clearance: 10mm
Required to Run:
4 x AA batteries for transmitter
*Note this car is equipped with an Ni-Mh battery. Please only use Ni-Mh batteries and Ni-Mh compatible chargers.
