Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
Iron Track MegaE8SCL Red Mayhem 1:8 Scale ARTR 4WD Brushless Short Course Truck RC Re
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 12-19-2018, 01:24 PM
yadac123
Default Iron Track MegaE8SCL Red Mayhem 1:8 Scale ARTR 4WD Brushless Short Course Truck RC Re
https://www.nitrorcx.com/16c229-red-artr.html
Experience the thrill of Short Course Racing! Enjoy the exciting power of four wheel dirt pounding power sliding action that only a four wheel drive short course truck can deliver. Look no further than the high performance Mayhem from Iron Track.
The Mayhem uses a three differential four wheel drive system to transfer the power to the ground. The power department is delegated by an 80amp speed controller and a powerful 36mm x 74mm 2075kv brushless motor enabling the driver manage those long impressive power slides that the Mayhem is capable of.
Taming all the jumps, bumps and ruts is the fully independent suspension system. This system also features adjustable camber, roll centers and many other tuning options should you like to change your driving experience to totally dominate your competition. The high volume “Big Bore” oil filled shock absorbers are also fully adjustable, allowing you to fine tune your suspension to whatever conditions you are facing with your truck. With all the dirt, dust, sand, smashing that this Mayhem is going to go through. Iron Track even provides a “dust cover” for the chassis to protect it from the elements.
The MAYHEM will not disappoint with its list of feature like:
• Hardened ionized materials are used for all joints and wheel axles.
• Ultra-tough, specially formulated plastic nylon materials are used
• All hard ionized steel differential gears
• High speed ball bearings as standard
• CVD front axles
Electronics:
3674 2075kv Motor
S8A 80amp Brushless ESC
9KG Metal Geared Servo
Specifications:
Length: 553mm
Width: 306mm
Height: 210mm
Wheelbase: 326mm
Required to Run:
Lipo Charger
3 cell Li-po Battery
2 Channel Radio and Transmitter
