Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
1/8Th 2.4Ghz Alpha Blue Exceed RC MadFire Electric Brushless Racing Edition RTR Ready
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 12-31-2018, 11:41 AM
yadac123
Default 1/8Th 2.4Ghz Alpha Blue Exceed RC MadFire Electric Brushless Racing Edition RTR Ready
https://www.nitrorcx.com/52c72-re-ma...ess-24ghz.html
The new generation of 1/8 Buggy EP Brushless are here with much newly added features and functions. Everything from the ground-up has been reinvented and modified to enhance the delight of having fun with the RC once again.
This massive 1/8 MadFire EP Brushless Buggy comes with 540L Brushless Motor for speed of swiftness, polished aluminum chassis to provide clean look as well as sturdiness, and adjustable shocks to have perfect landing. The impressiveness of the MadFire EP can be seen right out of the box when examine at first glance from the well-built interior to the magnificent exterior designs. From the front bumper to the back bumper all pieces have been build to last. Included in the MadFire EP are aluminum chassis plate, and heavy duty metal gear steering servo so you dont have to worry about it breaking. Even the rims are now hardened chrome rims and colossal tires to triumph over the world. Use the MadFire EP to climb off road terrain, stony hills, rocky backyards, or wherever the road may take you. For the MadFire EP will lead the way to new standards for the RC world and conquer all.
The 4WD Electric Brushless Monster Buggy MadFire EP will Push your Imagination into overdrive!
Features:
FX-2 Sport Radio& 540L Brushless
WheelBase:15"
Weight:5.2kg
Polished 6061 Aluminum Chassis Plates
Massive pre-glued 4.75" Tires Mounted on Hardened Chrome Rims With 17mm Hex Hub
1-Speed Transmission
Heavy Duty Metal Gear Steering Servo
Adjustable Threaded Aluminum Shocks
Hardeded and Coated Steel Gears
Multi-piece rollbar
Full Sealed Ball Bearing Set
All Assembled with Radio Control and Ready to Run Over the Competition!
Front CVD Drive Shaft Makes Smooth Turns and Prevents Dust Built-Up
Adjustable Front and Rear Roll Center
4mm Front and Rear Aluminum Shock Tower
3mm Aluminum Chassis
16mm Big Monster Shock
Includes:
1 x MadFire EP
1 x Radio Control System
1 x 80A brushless ESC with fan (pre-installed)
1 x 540L brushless motor with fan, 2150KV (pre-installed)
2 x 3300mah/7.4V 25C Lipo battery pack
1 x Instruction manual
No LiPo-Charger is included.
