titan 1/8 monster truck
hello.im from portugal and i bought an new 1/8TH SCALE TITAN SAVA YELLOW MONSTER TRUCK on nitrorcx.com and i want to know some things.
is that monster a real monster?
is this monter is an good truck?
i hope taht you help me..
tanks
tanks
TX
RE: titan 1/8 monster truck
It's a good truck, the motor is good. You can get parts from here. look under Redcat Racing to find your truck it's a Redcat Earthquake. [link=http://www.allaboutfunhobbies.com]www.allaboutfunhobbies.com[/link]
ok tanks
but all the people saiy me that is a really BAD truck because its impossible buy parts for it..
can i buy an roto start for my truck?
where?
help me please
where?
help me please
MI
ORIGINAL: filipe8
ok tanks
where?
help me please
ok tanks
where?
help me please
MI
ORIGINAL: filipe8
can i put an roto start in this truck?
which one?
which one?
TX
Ya have to make sure it makes it all the way tot he carb. YOu may have either a leak in the exhaust sytem or a leak in the fuel tank cap. Also make sure you didn't lean the highspeed needle so much that you cut the flow of fuel off to the engine.
TX
4 is alot, I be thinking maybe 3 turns out total at max on the high speed. Ya might actually be making up for a bad lowspeed setting now. Not sure though if it's running good and the temps are in range then what the heck run it like that as long as it's not spitting tons fuel out of the exhaust stinger or over heating you should be good
FL
hey guys sorry to bud in but just wondering i orderd a titan 1/8 scale rc truck and ive buin reading abaut this after run oil. wats it 4 ? and can u guys give me some pointers on were to put it wen i get mu truck. im a beginer wen it coms to cars and truks so sry for the stupid questions
PA
After run oil protects the engine after it is run. You pull out the glow plug and put a few drops in the engine, then give the engine a couple turns. I don't use this every time I run the car. If I plan to run it again within the week I normally go without. I do the same thing with my planes. I am fairly new to nitro cars but I have many planes. I am sure someone else will chime in here soon with there take on after run oil. It seems every one has a different method to protect there engines. I know a guy who never uses the stuff. He swears by WD40. His engines seem to run as good as every one elses.
MI
ORIGINAL: jony gallo
FL
oh ans sry i dident remember before um u know how wen the piston and sleve start to wear aut you should get a new one how can i check if thers eny wear withaut having to take the whole engin apart? and abaut how long do u think it lasts? the new piston and sleve i mean?
ok,on the piston there will be like little chips off i guess u say and if that is there u need a new piston and sleve. how long have you had it anyway, b/c u should not have replace it like every year or not even that much
FL
no im new to the hobby i was just gruping up lots of info on the maintanance and stuf for wen i get the truck. i just ordered it from nitrorcx.com its a savana blue titan 1/8 scale truck i should be geting it in a baut 5 days more or less. and can u tell me if its realy true that it gose 80 mph i think its a typo or som thing eneway chek it aut let me know if u think its a good buy or not.
