Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Exceed RC parts compatibility
Old 09-10-2012, 12:53 PM
  #76
RTCharlie
Default RE: Exceed RC parts compatibility
ORIGINAL: raidmax
Hi.. I have an exceed barca and was wondering if anyone knew weather the redcat aluminum universal joint is the same and will work on the barca... nitrorcx where I got the barca from wants $90 for 2 and I can find the redcat ones for $39. the photos of them look the same and the part number is the same but im not sure... thank you in advance for your assistance
Yes the unviersal joint that RedCat will work with our ExceedRC Barca.
-Charlie
Old 09-10-2012, 01:29 PM
  #77
raidmax
thank you very much... this will help me a lot
Old 02-04-2013, 01:31 PM
  #78
slowstang88
I posted this in a thread, but I noticed the chassis plates for the HPI RS4 and Exceed Hyper buggy look identical, as well as a few other parts including axle C's, hub carriers, and differential cases. Can anyone confirm or deny this? The buggy was given to me with a blown up engine so I used the front half of the chassis plate and steering/suspension for a 4wd trophy truck (4 linked axial rear end with wideners) and broke a C. I'm also running the stock single speed transmission from the buggy, Hobbywing 2250KV 3654 brushless and 2s 5000MAH 25C lipo and the spur has held up to it awesome! At first I ran a 5000MAH 3S and it was way too fast and broke the 2 front dogbones. If the diffs are compatible, I'm gonna get one and run HPI RS4 MT2 3.0 arms and cv axles to make it a little bit wider at the front for better roll stabilization.
Old 02-07-2013, 03:18 PM
  #79
Rampede
Anyone know where I can find some clutch shoes and springs. I can't find them anywhere they're for an exceed 1/8 scale madstorm
Old 02-08-2013, 09:19 AM
  #80
RTCharlie
On your MadStorm do you have the .21 or .28 nitro engine?
-Charlie
Old 02-11-2013, 12:07 PM
  #81
Rampede
.28 and I fixed it I used an LR-20 clutch set up and flywheel with aluminum shoes and vented 12t clutch bell tho I would like any information on it like where to get parts that are in stock lol
Old 02-11-2013, 12:09 PM
  #82
Rampede
Also what %nitro should I be running I bough the truck used through some guy I didn't know not realizing what I was getting into (first nitro I've owned)
Old 02-12-2013, 09:23 AM
  #83
RTCharlie
We have most of the parts listed here.
http://www.nitrorcx.com/2128rcenpa.html
We recommend using 20% nitro fuel with that engine.
-Charlie
Old 02-12-2013, 05:28 PM
  #84
Rampede
That's weird I couldn't find them when I looked but I never found the engine parts page. I have one more question, what is the tuning supposed to be set at
Old 02-13-2013, 09:50 AM
  #85
RTCharlie
This is the factory setting for the engine.
.28 EX engine settings Low speed needle clockwsie till stop, back out counter clockwise 3.5-4 turns
.28 EX engine Settings High speed needle clockwise till stop, back out counter clockwise 2.5
If you have anymore questions about the settings check this page out.
http://www.rcdiscuss.com/showthread.php?19858-1-8-Exceed-Nitro-Engine-Factory-Settings
Old 03-08-2022, 09:53 AM
  #86
Edward86
Default Exceed rc hyper speed 1/10 18 motor
Can I put a 2 speed clutch on exceed hyper speed 1/10 18 engine
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
