Mad Gear 1/16 Electric Short Course Green Truck 2.4ghz Ready to Run RC Remote Control
https://www.nitrorcx.com/72c-madgear...green-24g.html
Our Mad Gear short course truck now comes in a 1/16 size! It delivers big short course fun in a mini ready to fun package! The MadGear 1/16th Scale Short Course Truck is ready to conquer the dirt at your local track or favorite bashing spot. Turn your yard into a full on short course track! Featuring a 4 wheel drive drivetrain, adjustable suspension settings, and big bore oil filled shocks. Powered by an electric 380 brushed motor and a 7.2v 1100mah Ni-Mh battery this truck has enough power to power slide and drift around corners. Shock absorbing front and rear bumpers help protect the truck from minor collisions while the built in spring loaded servo saver will ensure the maximum life span from the pre-installed steering servo. Short course style rims and tires have also been included with this model to polish off the scale looks. Specifications: Motor Type: Electric Brushed RC 380 Motor Drive System: 4 Wheel Drive Length: 292.5mm Width: 195.4mm Height: 112.4mm Wheelbase: 173.6mm Front and Rear Tire Size: 64.3*30.6mm Ground Clearance: 12.5mm Shocks: Oil Filled Big Bore Shocks Speed Control: ESC, Servo and Receiver - All in One Unit Battery: 7.2V 1100mah Ni-Mh Battery w/ Charger Radio System: 2Ch 2.4GHz Remote Required to Run: 4 AA Batteries for Transmitter |
