MicroX Racing 1/24 Blue Micro Scale Rally Car Ready to Run 2.4ghz RC Remote Control R
https://www.nitrorcx.com/68c07-24-rally-blue-24g.html
MicroX Racing introduces its smallest most compact rally car to hit the market. Constructed on an molded composite chassis this truck sports an agile 4WD shaft driven drive train. A powerful brushed micro motor delivers tire spinning torque and speed to this already small and light weight chassis. Realistic rally car hatchback styling and details keep things fun and exciting. The 1/24-scale electric RTR 4WD rally car has all the features you would want in a hobby grade radio control vehicle. Proportional digital control, dedicated steering servo, high current electronic speed controller and battery. The vehicle is ready to run and comes with a rechargeable battery pack and charger. This Rally Car is fully equipped to attack the rally courses. All you need to do is take it out of the box, charge the battery and let it rip. Features: Shaft driven 4 wheel drive Molded composite chassis Coil shocks for dampening Realistic Rally Body Ready to Run 2.4ghz Radio System Off-Road treaded tires and wheels Shock absorbing bumpers Powerful motor system Specifications: Length: 175mm (6.8in) Width: 100mm (4in) Height: 70mm (2.7in) Wheelbase: 110mm (4.3in) Ground Clearance: 9mm (.35in) Steering bearing: Oil bearing Wheel: 33*12mm Gear Ratio: 1:12.6 Servo: 1.7g ESC and Receiver: 2 in 1 Transmitter: 2.4G Battery: 4.8V 220mAh Ni-MH Car Weight: 158g Required to Run: 4 AA Batteries for Transmitter |
