Exceed engine problem......
I have a exceed forza 1/10 buggy and the motor seemed to quit... i tried changing plugs and everything.. heating the engine and even broke the pull start...... also I lost one of the clutchbell bearings and none of my other nitro's bearings fit.... will exceed replace my engine????? Thanks!
RE: Exceed engine problem......
you can send the engine back and I'll get it working. how did you loose a bearing?
Andy |
sounds like you may be flooding it if it was hard to pull. when you flood the engine it will make the glow plug not funtion properly, sometimes burn it up. when it is really hard to pull, take your plug out, turn the car upside down and pull the pull start to clear out the fuel that is in the engine. pull it about 10-15 times and see if that works. it should start right up after you put the plug back in cause there will already be enough fuel in the engine. check your plug first and make sure it glows if its not glowing make sure your ingnitor is charged. if it is charged you should get a new plug.
you may know this, so if so just send the motor in. if not i hope i helped. |
| All times are GMT -8. The time now is 09:42 AM. |
