RCU Forums
-   Exceed RC Support - Nitro Cars (https://www.rcuniverse.com/forum/exceed-rc-support-nitro-cars-472/)
-   -   1 Speed Nitro Rc Electronics Problem (https://www.rcuniverse.com/forum/exceed-rc-support-nitro-cars-472/7786586-1-speed-nitro-rc-electronics-problem.html)
ish320 07-29-2008 08:26 PM
Hi, I bought a 1 speed beginner nitro buggy from raidentech, and it worked fine until now. The controls in the car works fine, but as soon as i turn the engine on, the controls start to move by them self. So, i see that the servos move forward and backwards as soon as the engine is turned on. I changed the batteries, the crystal is in properly, and all the electronics seems to be wired together. If the engine is off, every thing seems to work normally. HELP!!!
firebird78 07-29-2008 08:36 PM
RE: 1 Speed Nitro Rc Electronics Problem
hmmmm either your engine is causing interference or you have a bad wire in your reciever....im betting on a bad wire in the reciever...with the engine running it vibrates and messes with your connection....either way the people you bought your rc from should do the right thing and exchange your radio system...
ish320 07-29-2008 09:11 PM
I took all the wires out and and put them back in, even though this is still happening.
firebird78 07-29-2008 09:28 PM
bad wires inside the reciever...like some soder came loose
dominicevans 07-29-2008 09:43 PM
man I have the same prob but i think its the crystals thats gone futtin nucks . I also opened my reciever up and everything seems fine but the crystals are what are messed up or the slot for the crystal
yadac123 07-29-2008 10:16 PM
please make sure your antenna is not wrapping around the battery or touching any metal parts.
Andy
ish320 07-29-2008 10:18 PM
the antenna is away from the batteries, and its only near the reciever
yadac123 07-29-2008 10:24 PM
what's your order number so I can exchange you a receiver and crystal just to be safe.
Andy
ish320 07-29-2008 10:26 PM
I emailed you the order #
ish320 07-30-2008 09:25 PM
Where can I buy the receiver and crystal, I cant find it any where on raidentech.com
dominicevans 07-30-2008 11:29 PM
man parts support suck for exceed
no description on websites of their parts which are hard to find...
yadac123 08-04-2008 08:32 PM
have you even look at http://www.exceedrc.com/sparepart.html?
Andy
ORIGINAL: dominicevans
dominicevans 08-05-2008 08:27 AM
exactly you have like only 5 sites to buy parts from....no hobby shops...no nada
ish320 08-05-2008 12:01 PM
so, what exactly do i have to buy in order to make it work again!
GlassBullet 08-05-2008 12:15 PM
I'm gonna have to go with dominicevans on this one. It really bugs me how there are no description of parts, not even a sentence.
dominicevans 08-05-2008 12:59 PM
ya if you dont know the exact name of parts you have to guess by the black and white picture
yadac123 08-05-2008 03:00 PM
I've sent you a pair of crystal and receiver to fix the problem.
Andy
dominicevans 08-05-2008 03:11 PM
how much for a pair of crystals and a receiver
