Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
"Extreme" speed doesn't actually apply to me but. . .
Old 10-09-2010, 02:22 PM
LongRifles Inc.
Default "Extreme" speed doesn't actually apply to me but. . .
. . .Ihave a 50 size Voodoo mustang that I stuck a 91os fx into.
I have a 10x10apc on it and flew with it today. It's quite windy (20-30+) today in S.Dakota so it's hard to tell what the bugger is doing. Ran pretty good on the down leg side!
Anyways, anyone have a good speed racer prop set up on this motor/plane combo? I'm running home brew 15% nitro/20% oil right now and it'll twist this prop at 13,800 on the ground. Only engine changes are removing the cone from the muffler and I'm using a Tettra bladder tank.
I'm thinking 11x10, 11x11, or 11x12 even. (apc)
Thanks!
C
Old 10-10-2010, 07:34 PM
freakingfast
Default RE: RE:
11X12, 12X8, 12X9 APC or 12X8 S-2 MAS seem to work well on a tuned muffler or tuned pipe and should work with the stock muffler with or w/o baffle. I've tried those on my Phoenix Strega converted to Stiletto and the props are all close to the same performance on it with the same header length. If I had more time to fiddle with the header, one of those may shine well above the rest. I saw about a 2000 rpm jump over the stock muffler with a tuned pipe with those props. The 10X10 may not be enough prop for that engine and you may do better to move more air at a lower speed around the fuselage (more diameter & less pitch). I did tach a 10X10 on my 91FX and it did 14,950 on pipe (the pipe was tuned for 13,650 power peak) but I didn't try that prop on the plane.
Old 10-24-2010, 08:18 AM
jaka
Default RE: RE:
Hi!
What engine size??
For a .46-.50 two stroke I would choose a 9x7, 9x8 APC.
For a .61 two stroke I would try 10x7,10x8,10x9 APC.
Aah! .90 twostroke...then I would try a 10x9,10x10,11x6,11x7 or 11x8 APC.
Old 11-06-2010, 01:10 PM
LongRifles Inc.
Default RE:
I flew the other day with a 12x10 APC.  Seemed to work well.  I'm at 3500ft elevation so this may be why I'm getting away with the added pitch.
I've ordered a MAC header/pipe set up and a couple 12x12 APC props.  Maybe that will wake this thing up!
I'll post results.  A buddy is a cop and enjoys making "creative use" of his radar gun.
More to follow. . .
C
Old 11-06-2010, 03:05 PM
jaka
Default RE: RE:
Hi!
What rpm??? I think 12x12 is way too big!
You must up to 15000-18000 rpm to get any speed!
Old 11-11-2010, 10:35 AM
LongRifles Inc.
Default RE:
The 12x10 APC screams!  I flew the snot out of it on Sunday and all was good.
Yesterday my MAC pipe arrived along with a pair of 12x12 APC props.  I'm optimistic.  I think this'll wake things up a bit.  If I'm down on RPM my intentions are to first shim the head and spike the fuel with a bit more nitro. (I have gallons of the stuff along with a hydrometer for "cooking" my own fuel)  If that "kinda" works I'm going to raise the exhaust port a smidge.  This will raise the usable RPM range of the engine.  It'll surely kill some of the "grunt" down low but I don't care.  This is a speed plane.  Just has to idle reasonably well and transition to WOT for take off.
I'll get some radar gun #'s once she's all done.
