Sheet wing racer revisited
Gas Flyer....Us Little Flyers got to stick together...!
My neighborhood has quadrupled in size over the past 25 years and flying a 5 pound plane at 200 mph is getting too risky where I've always flown. Even the local private aviation traffic is becoming more of a liability where I fly.
It's almost time to pack up and move to the high desert east of the mountains.
Ahhh that reminds me I wish I had some decent video of the Toucan. The solo laps over the field looked and sounded like a miniature F3D race. More rpm too. Well, honestly not much more than an MB Profi or the like at full song!
Speaking of which. this would be the real deal as far as a speed twin is concerned.. egads.. https://www.youtube.com/watch?v=IUxu9QfYDFk
oops, sorry gas flyer - back to the topic of your thread. But do watch the video above if you haven't already seen it!
It was close to, but not quite 150.
That engine continues to get better and better with age.
It won't be much longer and I'll be forced to find a different place to fly.
This field is 5 minutes from my house. The next closest 100 acre hay field is 30 minutes from here, but I don't have any permission to fly there.
#31
This one is 2 bucks and change www.youtube.com/watch?v=u0MN6NHChZI I really like .15s. These don't use any nitro either. I bet your Profi would go better with a pipe too.
#33
That CL speed is proof that small blocks can fall into the extreme speed category all things considered.
Since the subject of wing flex was brought up you guys should look into what some guys are doing with CF tow in making spars for thin wings.
Another little interesting trick is "disser" a grid pattern of tow on a bias to the wing this really beefs up the wings torsional strength.
#34
I maintain that cracking 200 with the Profi F2A .15 is not going to be that big a challenge. Not a cake walk, but point being the power potential is clearly there if you believe that RC models will always be cleaner than a model on lines. I do.
#35
#36
WA
Looks like I woke up the nest and some flash backs. The Tripps was based on the CP V-tail sheet wing racer. I glad I'm not the only one that see this as a challenge.
#40
Thanks for pointing that out...!
As a creature of habit, I almost never scroll down to that forum.
You did a super-dooper job on that one...!
I tried scratch building a canard years ago and never could get the proportions to work right.
The plane mostly ignored the canard no matter where I put the CG or no matter how much area I gave it. It took a lot of throw for the plane to react and by then the canard was acting like a spoiler.
I think [with 10 year's worth of hindsight] the canard was too close to the wing, but the project was shelved after too many botched attempts to make it work.
#42
I just did a search. There are build threads etc. http://www.rcuniverse.com/forum/1-2-...99256-swr.html Has the Killer Buzz
#44
Here is my SWR with a PRF flying with a AP .061 and Profi 1/2A Pipe.
Mini 1/2A Skorch:
http://www.rcuniverse.com/forum/1-2-...ni-skorch.html
First flight on the pipe:
https://www.youtube.com/watch?v=oiLQfuQ4y64
Mini 1/2A Skorch:
#47
Skorch II version with a Vertigo.07 converted car engine Profi pipe. /35.5in span 140sq.in
https://www.youtube.com/watch?v=h47Vosb0JFE 1st flight
5x3 / 25.47k / 183w / 27oz static / 28.47 / 81 mph
2nd trip out:
4.75x4 / 23.578k / 144w / 19.3oz static / 26.483k / 100.4 mph
4.5x4 / 23.98k / 127w / 16.96oz static /27.631k / 104.7 mph
2nd trip out:
#49
Yes the 5x3 originally used to insure fast up and away for the crucial trim flight to my surprise the plane flew well with it as noted by the fast passes vertical climbs was great as expected.
The .07 makes the prop useful. A Norvel .061 spins the prop at 23.8k static vs 25.47k with the .07 for a good jump in power.
A single blade prop would be a good step forward - alas I have none.
Will test a APC 5x5E this weekend static readings indicate the plane will top out around 117mph.
I think the 4.75 x 4.75E may help keep the heat down its still topping out in the low 90's here in
TX. Will post a vid if the results are good I always record all prop testing flights for review.
#50
The rough head-math is pitch times thousands of rpm less 5% = 3" x 20k = 54mph, 3" x 25k = 67mph . You can spin the living crap out of a 5-3 and you'll still top out in the double digits.Lots of pull out of the corners though.
