Thoughts on VQ Models Dago Red
My Feedback: (58)
I'm open to trying anything once and fun things twice. I talked for a while with Dub Jett today and ran him through the set up. I'm going to give his suggestion a try but I did order an extra spacer just to be safe. Getting a gold muffler shouldn't be a problem if I'm sad with the performance.
My Feedback: (58)
Well, I put the second spacer in due to moving the engine would have put the tank WAY above the carb centerline. I was running the engine in on the airframe and tuning it when the throttle stop backed out and BAM the engine stopped. Jett 76 ingested the spring from the carb and locked up solid. Off to Texas it goes for repair. Gives me time to build the SD.
#37
My Feedback: (58)
Thanks to the wonders of CF and laminating resin the firewall is unscathed.
I did manage to disassemble the engine tonight and get the piece of spring that was locking things up out. It took a bit of doing but thankfully I found that pulling the liner gave just enough room to pop the rod off the crank and remove the piston.....then a little (ok a LOT) of pressure and the crank slid out. I will have to do a little polishing on the crank but I think she will live again.
#43
CA
411 the VQ Dago red is a .46TS / .70FS. class, hardly for a 1.15 or anything close. I have two and this plane is NOT built for much above either recommend engine structurally. I put in a .91FS and it was literally shaking it apart. VQ's are pretty, BUT the materials used are 2nd class. If you're hell bent to use that YS1.15, better get a far better plane from a far better Mfr. VQ's are made for smooth running 2 strokes. Vinh Quan's son's "Phoenix" brand models are made a bit better, but cost more.
