new speeder
Old 03-18-2023, 11:23 AM
  #401
Clugh
Clugh's Avatar
Meier111 wrote:
This has something to do with tension-soft and tension-stiff.
Quote from Wikipedia (https://de.wikipedia.org/wiki/Transf..._Transformator):Hello,
it's about the stiffness of the motor = speed drop per motor current increase Name:  biggrin.gif
Greetings
Micha A
Audiosmith
User
Thank you Micha, yes Maier should first understand what this is about before he explains everything and again only distracts from the topic!
~Audiosmith~
Dude! what are you talking about he hasn't disproven Meier or supported you. The dc resistance is the same in the comparative machine dumm ass 1milli and the single layer uses 3% less to generate the the same torque by Kw. The Kt is set by the Kv. The other issue is the Powercroco DELTA ac resistance is 10 times that of the Lehner.
Old 03-18-2023, 11:34 AM
  #402
Clugh
Clugh's Avatar
Here's some simple azz motor math Helmut does not disprove ever with the bull**** Thomas has posted.
Audiosmith. is very dense and does not know hes talking about!
Kt =1/Kv
Torque = Kt x amps x Kw
Kt=1/1kv=1
Kt=1
Torque = Kt x 1 amp x (Kw) = 1
Lehner Torque = 1 x 1 amp x (Kw1) = 1
HkII Torque = 1 x 1amp x (Kw.93) = .93
Black Karma =1 x 1 amp x (Kw.96) =.96
7% less torque in the Hk in any situation then its also less efficient. The motor never wins. On paper or anywhere else. These amateur clowns are wasting everyone's time. He has the lowest winding factor and efficiency in the pack.
That post is just plain stupid but u plan to keep posting the same wrong crap misquoting the EE!
Thomas and Ralph please sell your bs to Bundeswehr university. They will never buy it!
ITS TOTAL BS MICHEAL! The hammerless slots, magnet segmentation, and the litz wires on a much higher level than the formula E the guy posted in his own F! thread the Lehner already has incorporated so how is it that the argument not dumm as hell?
The Lehner actual has more. The magnet segmentation is much greater. They are also reverse step which brings a sinus operation which incorporates very well with MGM comp pro.. The spoke pm is not going to do that.
Your ability to absolutely fill the motor forums with incorrect bs is truly second to none.
How could your stiffness be more and he utilizes 7% more of the same copper to generate the torque in a machine that is more efficient from the onstart.
I G N O R A N T !
They will never build an inverter so I can see now I'm wasting my time.
Hubert
Old 03-18-2023, 12:47 PM
  #403
Clugh
Clugh's Avatar
Well the 3 of us are in here. whats up? U gonna just look or talk Ralph? The Talega based Komar PCB Template and BOM is also here you see it. 476 amperes!
You afraid?
Old 03-18-2023, 01:44 PM
  #404
Clugh
Clugh's Avatar
Hey Rooman! The flying giants threads will be open tomorrow! Absolutely nothing has changed with the post there or my opinion of the Powercroco or Audiosmith.
Old 03-18-2023, 02:18 PM
  #405
Clugh
Clugh's Avatar
Hi Thomas,
15 KW ? we only start at 30 KW, small turbogenerator with 40000 rpm. Up to 400 KW 35000 rpm synchronized with a Hall probe, no syncloss. Reluctance motors with Dr. Kosta Kanelis up to 60 KW 2000 rpm. Vehicle propulsion up to 600 KW per tire , Marine propulsion up to 2 MW . Flywheel storage from 2 MJ to 8 MJ with 2000 kilogram CFRP flywheel at 180000 rpm, Mach 2 peripheral speed. Once we managed to burn down the wiring harness completely, had to let the test stand rest for a week until everything had subsided. Have you ever driven in a vehicle powered by 8 x 150 KW wheel hub machines? off-road . Have a look that you attend a few lectures and ask Plettenberg why their F3B engine is so fast and why the engine has won more world championships like no other.
in remembrance.
Helmut Schenk died exactly one year ago on 18.03.2022.
Happy Amps ChristianHappy Amp ́s Christian
GO FAST TURN RIGHT AND GET OUT OF MY WAY A
Audiosmith
User
You always show off this show-off, is really poor-throated!
Always distract when it gets tight and again not recognize Helmut's n/n0 engine rule and then remember him, that's really disgusting, really go to the doctor!
Old 03-18-2023, 02:19 PM
  #406
Clugh
Clugh's Avatar
There is nothing tight for us about your post audiosmith they are no more than humorous.at best. People pass away just like my friend James but regardless Helmut Schenk is no author of any motor rule. And you were told long ago to stop using his name in vein because he has never taught anyone including you that the dl is a better machine. Ur leading them on with another fable signing his name to it just like you did when you told the forum the 320 could do more that 16 khz. Do you remember that post then when its TIGHT you request Gerd lock them out of the thread. Nothing is more sick than you continuing to lie to the boys and drag it out to save face. Youve never ran halls or an outrunner or with the YGE so you dont know what it will do.
You lost! and should finally tune in to the "laboratory technicians" U tube channels to learn.
Old 03-18-2023, 02:43 PM
  #407
Clugh
Clugh's Avatar
So the larger picture is Helmut is another genius gone while you argue versus build.
A waste of his gift!
Weve went to all the Drs. and they all tell us the same thing. You are wrong.
Regards
Hubert
Old 03-18-2023, 03:34 PM
  #408
Clugh
Clugh's Avatar
Meier111
User
audiosmith schrieb:
Aber wenn wir doch schon so schön am Plaudern sind, erklär mir doch bitte warum der viel gelobte 4140 nach deinen Angaben so ein extrem weiches Drehzahlverhalten hat, wodurch das versprochende Eta garnicht erreicht werden kann?Das hat was mit spannungsweich und spannungssteif zu tun.
Zitat aus Wikipedia (https://de.wikipedia.org/wiki/Transf..._Transformator):Transformatoren mit hoher Kurzschlussspannung heißen spannungsweich, solche mit niedriger Kurzschlussspannung heißen spannungssteif.Auch bei Trafos sinkt der Wirkungsgrad, wenn sie spannungsweich sind.
Wer keine Lust hat zu wissen, wie ein Transformator funktioniert, braucht sich nicht wundern, wenn er beim Motor die Grundlagen nicht versteht.
Ein Elektrotechniker muss sich immer zuerst mit Transformatoren beschäftigen, bevor ihm was vom Motor erzählt wird.
Die ersten drei Sätze sind schon fundamental wichtig. Die muss man verstanden haben.
Und das ist erst der Anfang der Geschichte...
~Meier111~
Old 03-18-2023, 03:39 PM
  #409
Clugh
Clugh's Avatar
"Auch bei Trafos sinkt der Wirkungsgrad, wenn sie spannungsweich sind.
Wer keine Lust hat zu wissen, wie ein Transformator funktioniert, braucht sich nicht wundern, wenn er beim Motor die Grundlagen nicht versteht."
Meier111~
Old 03-18-2023, 03:40 PM
  #410
Clugh
Clugh's Avatar
Regards
Sweet pea.
Hubert
Old 03-18-2023, 04:09 PM
  #411
combatpigg
combatpigg's Avatar
Not impressed.
Try working with 500 MCM copper...then get back to me.
Old 03-18-2023, 04:11 PM
  #412
Clugh
Clugh's Avatar
Look what happens with this bipolar SL winds harmonics when you goto a 4 layer asymmetric wind and cascaded bridge.
Old 03-18-2023, 04:14 PM
  #413
Clugh
Clugh's Avatar
Then in 4 layers look what happens to the two pole which is what eats the rotors magnets and generates the copper proximity. The leakage inductance is much lower with this machine.
Old 03-18-2023, 04:17 PM
  #414
Clugh
Clugh's Avatar
Give thanks again to the real Drs at the IEEE.
Old 03-18-2023, 04:21 PM
  #415
Clugh
Clugh's Avatar
Originally Posted by combatpigg View Post
Not impressed.
Im not either. Unless you packed it within a 40mm diameter What a popshot....LOL!
Not at all about impressions but proof of the tangible science behind the wind..
Old 03-18-2023, 04:31 PM
  #416
Clugh
Clugh's Avatar
If you want to impress me show us the hand wind or a 7.2hp 1/2 A.
Old 03-18-2023, 06:19 PM
  #417
combatpigg
combatpigg's Avatar
Don't lie to me.
You would have to be extremely impressed with yourself to hijack someone else's thread with 100s of unanswered and unloved posts.
Old 03-19-2023, 03:41 AM
  #418
Clugh
Clugh's Avatar
Nice photos!
Anyways.
Michael here is my flow oven the working area is 14.7 inches by 16.5 inches. It set me back 284.00. Half a PAW!
T962A Reflow Soldering Machine
This reflow soldering machine has a big infrared soldering max area, reaching effectively: 300 x 320mm. Thermal cycle accuracy is maintained by closed-loop microcomputer control with infrared heaters, thermocouple, and circulating air. This machine can solder most PCB boards small parts, for example, CHIP, SOP, PLCC, QFP, BGA, etc.
  • Infrared Reflow Oven Model: T-962A
  • Rated Power: 1500W
  • Effective Soldering Max Area: 300 x 320 mm(11.8 x 12.6 inches)
  • Power Supply: AC110V/60Hz
  • Temperature Range: 0℃-280℃
  • Cycle Time: 1~8 min
  • Rated Duty Cycle: 100%
Old 03-19-2023, 03:58 AM
  #419
Clugh
Clugh's Avatar
A convection microwave will work but toxics where u cook your food is not cool.
Regards,
Hubert
Old 03-19-2023, 04:06 AM
  #420
Clugh
Clugh's Avatar
This is JA's prop balancer.
The basic one I use is commercially available.
Old 03-19-2023, 05:08 AM
  #421
Clugh
Clugh's Avatar
A gift for the hate troops
Itz ready to mill and drill everything on point including the thermal vias sweet pea
Luv,
Hubert
Old 03-19-2023, 06:31 AM
  #422
Clugh
Clugh's Avatar
Old 03-19-2023, 06:36 AM
  #423
Clugh
Clugh's Avatar
Regards,
Hubert
Old 03-20-2023, 04:37 AM
  #424
Clugh
Clugh's Avatar
Dec 27, 2019, 06:40 PM Hummina
Registered User
Thread OP
United States, CA, SF
Joined Jul 2014
1,583 Posts Discussion
Why LRK shows higher winding factor than DLRK w 12n14p
The Dr that created this that WE ALL FOLLOW is wrong according to Ralph and Thomas first of all.
Old 03-20-2023, 04:41 AM
  #425
Clugh
Clugh's Avatar
Hi Humina,
have a closer look. See that the original LRK winding has allways only the statorteeth that belong to a phase has the same position under the magnets like the other statortooth. So the rising of the electromagnetic induction is at the same time . DLRK has different position of the stator tooth to the magnets. So the induction starts first in one of the statorteeth and 30 degre later in the folowing statorteeth . As the belong to the same phase the induction volts are lower and not running in time. This is a mix max that is less efficancy , has lower winding factor .
Try the best and wind LRK the SPS winding system.
