Patriot Wing Question
TN
I am designing a new wing for my extreme speed plane and I want to pattern the wing after the Patriot. What is the maximum thickness at the root and at the tip?
By the way, if anyone has a drawing of that wing I would appreciate a copy!
TN
RE: Patriot Wing Question
Thank you for your response. If you would make the following 4 measurements I would appreciate it very much.
1. Length of the longest wing rib.
2. Length of the shortest wing rib.
3. Maximum height of the longest wing rib.
4. Maximum height of the shortest wing rib.
What I am really trying to figure out is how thin is the airfoil of a good, high speed plane.
WI
The large rib is 13 inches long and at the highest point 1 13/16 inches tall. The smallest rib is 4 7/8 inches long and 15/16 inches tall.
