Official Whiplash Tech Site
#109
I can understand engine collectors who build custom showcases for these mechanical marvels, give them special effect lighting, do historical research, polish them, restore their innards with custom made piston rings, new bearings, restored ignition systems, etc.
I just can't see the same devotion to electric motors.
#113
My Feedback: (85)
Appreciate the opportunity to get a NIB Whiplash from Dirt Dummy.
Finally got my Whip painted. The weather has not been great Temp and Wind wise.
My Whip had some issues that I believe are fixed but only the RC Gods know for sure. The rails were cut out for a larger engine but the original owner shelved the project so aircraft ply was epoxied in and cut for the OS 46. The skin has several bubbled areas mostly on the left close to the elevon. Had seen in one thread that the elevon tore off. My elevons were also stiff. So I did the mod recommended by LGM graphix by cutting the elevons free and using Robart Hing
epoints. They are installed using Hysol. Great movement with no binding. Will let paint cure will did the Orange today and then final assembly.
Pete
Pete
#117
My Feedback: (85)
Was making good progress programming until one of the HS-7985mg servos abruptly moved 45 deg and started to chatter not holding neutral. Using a NIB Futaba 617FS Rx on 6v. Plugged the servo in another channel same, plugged it in my Hitec programmer and it still chattered not holding neutral. Sent it off to Hitec prob a bad pot. This was a NIB servo and I have had good luck with Hitec in the past. Research on these had been positive.
Looks like it will be at least another week or so before a maiden.
Pete
Pete
#118
My Feedback: (85)
Well it's finished!!!. I got the HS-7985 back. Hitec said the amplifier was burnt out and they fixed it. Everything works no binding with the new hinging. All up weight is 4.9 lbs, Added 3/4 oz in front of tank to balance right at 2.25 inches. Will use a Higley Heavy Hub for first few flights if I want less nose weight I can swap it for a Dubro Spinner Nut. To protect the throttle servo from vibration I used a Dubro control over-ride servo saver Cat# 120. Hope to maiden this weekend weather permitting.
Pete
Pete
#120
Pete
Pete
#121
My Feedback: (8)
I hand tossed mine all the time. But I will agree, you can't just let go and it won't just fly out your hand. You do have to give it a good toss forward with throttle at full.
I however would recommend getting a 2nd person that you trust to toss it for you.
#123
#124
My Feedback: (85)
MJD,
Thanks for the tips. I did give the engine 2deg rt thrust.
AtomicFrawg,
Glad your dusting yours off for the spring. Too bad you could not salvage the molds.
Weather great today so I ran the engine for the first time since the rebuild. Using the APC 9x7 I got 16500 rpm's with a good idle and transition. Probable still a few clicks rich. Was using the Whiplash launcher to hold the plane while adjusting the needles and running it. Had to make some adjustments to the pin that holds the plane so it's all good now. Hate it when you get to the field and Gremlins chew at your toes so I was glad to get several thing sorted out.
Pete
AtomicFrawg,
Pete
#125
My Feedback: (85)
WOW
Successful maiden but the Gremlins were out. for yesterday's adventure the launcher worked great but the whiplash could not get enough speed and altitude so I broke a couple of props then raised the end on a couple of bricks and I was able to get into the air. She had a nasty hard left roll that would not trim out. In fact the more right trim that was added the worst it got like it was reversed. I was able to safely land it but broke another prop. In going through everything the elevons worked perfect and correct but the trim was in fact reversed. A new one on me so I was able to get into the programming for the trim. The setting was +30 so I changed it to -30 and it now takes trim normally. Had I lost the plane I would have never figured out the programming error that almost killed it.
Today I brought out my workmate and a table to raise the launcher and that was the ticket. Both launches and flights were good except that the engine quit each time about 2 min into the flight. Engine not hot glow plug not burnt out. We ran it again without refueling and the fuel was foaming bad.
So. I have some ideas about remounting the tank to reduce vibration if that does not work then a Tetra bladder tank will go in.
Will get the videos on soon. I deeply appreciate the ideas and suggestions that are in ALL of the Whiplash threads and incorporated into this build. I know my success this weekend rested on your shoulders.
Pete
Pete
