Combat Models F-16
#54
RE: Combat Models F-16
Going for a custom tuned OPS 65 RI/RE, with byron pipe for pusher. Perry Vp-30 pump, and custom 9x10" pusher prop.
been promised 150mph +
So Razor, you can keep quite about this ones speed
#56
Does anyone know what size tanks are in the Pusher F16N???
Also, can anyone supply the instruction pages for the intallation of the engine mount for the pusher version?
#57
My Feedback: (10)
Dave, you need to contact the guy I told you about in Florida. He may be able to extract the portion you need from the DVD and e-mail it to you. I am sure he will send you photos of his plane and how he mounted the engine. He may also have the ability to scan the manual. If you need his info again pm me.
#60
My Feedback: (10)
I thought Angel wanted it?
All I have are those MVVSs you don't care for. Other than those I don't have anything that will use it.... right?
About the vid there is a guy in Florida who made a DVD of the one I borrowed from Angel. If you need to get into contact pm me. BTW it is for the pusher version. However the glassing techniques are priceless.
#61
My Feedback: (40)
NJ
You can put 2 round 6oz or 8oz both tanks goes front of the main gear,The 8oz needs to be cut out a little bit. I have 2 8oz tanks. Oh! do you have the byron pipe . How much
#62
My Feedback: (10)
Razor has the pipe, but he seems to be distracted while harrasing Dave from across the pond. I fitted a 6 up tonight, the length is ok but I will need to carve a little out in the main fuse. I plan to get the motor all situated before I go permanent with the tank. I have a pump but bu the look of things I don't think I will need it. (that ought to get James' attention).
James, if you are loitering near here you should change your sig to reflect your un-official censorship of the speed prop plane forum in honor on your abuse to Dave.[sm=spinnyeyes.gif]
Razor's proofreader[sm=bananahead.gif]
#67
My Feedback: (10)
At 11:00 I get confused too, maybe too much medicine and association with my Canadian freinds and their ice cube clubmates.[sm=spinnyeyes.gif][sm=bananahead.gif].
About the paint? The vid had the guy using water based acrylic. Is that what you did?
Thanks.
Thanks.
#68
My Feedback: (50)
Oh heavens no- I did not "build" it... I bought it!
The video does mention using that acrylic foam friendly paint as I recall--- Keep in mind I have no real "uselful" information in any of my 2000+ posts
I can fly though-
I can fly though-
#69
My Feedback: (10)
Bought it???[:'(] Oh I'm sorry. I thought I was amongst a true modeller. Sorry to pester you. BTW the fuel tank is only 4.5" from the carb. I am going to look into some acrylic primer tomorrow.
How about you Dave, what are you using?
Razor, it's all in good fun brother.
#70
I too didnt build my F16, However I use the Humbrol Fed Standard paint range. Thinned down and sprayed through an Aztek A320 airbrush with large coverage nozzle. Then Lacquered.
#71
My Feedback: (50)
No problem... Although less building has given me more time to practice things like takeoffs and landings (I have many more takeoffs than landings-[X(])
I can even fly upside-down for a couple seconds
Where are the pics of this supposed F-15 Tractor prop-jet?
WHat paint scheme you goin' with? Tiger? Battleship grey?
Keep us posted- just for the record that airplane flew better when we clipped the wings a bit
