This little thing moves!!!
My Feedback: (40)
NJ
Scratch build this plane for speed, and to fly smooth. has a wedra 50 speed tune pipe, 34in wingspan, fus, is 36in. washout in the wingtip. 3lbs. with full tank. And the tank is on the C/G here some pic. (Rifle 40 to 50 )
My Feedback: (40)
NJ
RE: This little thing moves!!!
If you want more inf. you can e-mail or call (201-430-3852) after8.30pm, yes i experiment more stable in low and high speed . the tail was bounce around on the magmun.Yes I would like to kit or build and get feedback on this plane.
My Feedback: (40)
NJ
That has nothing to do with it. Its how you fly the plane. some people like to yank on the sticks. And some have smooth fig. and know what they doing. ( Rifle movement Is 1/2in all around, no expo.
ON, CANADA
I like that design. Sure is light. What airfoil did you use?
The wheels are cool. How is it on take off, or do you hand launch?
I have a MVVS .40 with rear exhaust that would go great on this design.
very true, i remember one guy saying it didn't turn unless he gave it tones of elevator, umm not that type of plane.
i've test flown a delta, lovely and smooth it was, gave it to him and it looks like a bronco
My Feedback: (40)
NJ
Every body flys there planes diffrently, some will tell you nose weight is better( looking for a higher stall rate. Or taking off full power before it reaches speed then pull the stick back than whatch the turn letf in to the ground doing nice cartwheel). OR tail weight , Now those are the one to see, Its like a rollercoaster ride [X(][&:] believe me i Know I tested a geebee and the guy said c/g was on the spar, i said ,are you sure, yes, then lets try it. have you kneese shaking? well mine was.
My Feedback: (40)
NJ
Hello guys well took some vid , but not that great so here it goes anyway. Webra 50 on 9x8, broke the 8x8 prop. well i have to try some other way because it dont work with MPJ. hey what can i use to show it.
My Feedback: (40)
NJ
Today was a good day for flying, we put a GPS in the Rifle today and it read MAX SP:143MPH , CL 1,243ft Webra .50 sp. on coolpower 5% fuel. and prop 8.5x7-8.5. not that fast but its ok.
