Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
AKM SU-27 Flanker-Does Look Good
Old 02-11-2010, 07:38 PM
  #1301
Cyclic Hardover
Cyclic Hardover's Avatar
Default RE: AKM SU-27 Flanker-Does Look Good
ORIGINAL: Billybuck
I was wondering if 1/8 fully threaded rod would work for elevator and rudder instead of solid rod?
Also, where do you buy the plastic bearings (look like hinges) that you use to attach the rod to the elevators?
Also has anyone done a fixed gear setup. If so, what did you use for main gear mounting blocks?
Someone here said there are no dumb questions. I'm testing that theory a bit.
Thanks for your thoughts on this.
THreaded rod is not a good idea. Vibration and break it. I've seen some use them for servo connections. Your flying on borrowed time
Old 03-27-2010, 09:52 AM
  #1302
kleinssz69
Hey guys. Just a heads up if anyone is interested. I'll be putting my SU-27 up for sale here when I find the time. It's about 95% complete, installed fuel tank, engine mount, Spring Air retracts and the air kit, etc, but no struts or no electronics. Send a pm if you want all the details.
I have little time to finish this, and I think the planes going to be too fast for me to handle as well. I'd hate to wreck such a nice piece of equipment. Would love to finish it and have it on display, but I need the $.
Old 04-09-2010, 06:19 PM
  #1303
csanlley
kleinssz69:
Uhmmm, sounds interesting... can you post some pics? and the details of what's included.
Old 04-10-2010, 09:46 AM
  #1304
kleinssz69
t
Old 07-07-2010, 06:32 PM
  #1305
roly1129
roly1129's Avatar
Here is one that I'm finishing for club member. He got it at swap meet it was built but not covered. Had to refit the retracts to use the struts, redue gear cut out for the new struts.
ID:	1464718   Click image for larger version
Old 07-09-2010, 05:39 PM
  #1306
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
ORIGINAL: roly1129
NICE..wow
Old 09-21-2011, 06:34 AM
  #1307
pedroglow
Hello everyone, but I look a lot this forum, I just register as a member, I would like to address some concerns I have with my Su-27 Flanker .....
I wonder as you ride the engine once built the plane's nose ....??
thanks in advance and receive a warm greeting
Old 09-21-2011, 09:07 AM
  #1308
bob27s
My Feedback: (19)
bob27s's Avatar
Was wondering if you finshed up the Flanker project over the summer? How did things work out?
Old 09-27-2011, 01:54 PM
  #1309
pedroglow
Hello everyone.
In this link you can see in detail the construction of my SU-27.
a greeting
http://www.miliamperios.com/foro/aeromodelos-escala-f4/flanker-t176911.html
Old 10-22-2011, 08:53 AM
  #1310
jaaron01
So i've finished up the Topflite Stinson Reliant, and winter is starting to set in. I think it's time to finish off the Flanker and get her ready for spring. Anyone have problems with the wing tubes shrinking after a couple months? If so anyone have idea's on a replacement tube? I've got 1 wing about completed, but the tube has shrunk in the wing and I had to pull it out, now I need a replacement.
Jim
Old 10-23-2011, 11:16 PM
  #1311
pedroglow
Hello again, progress in my SU-27
[/quote]
Old 10-24-2011, 04:11 AM
  #1312
jaaron01
Looks good.  I got both my fins glued on, now I'm working on getting some of the other bit-n-pieces sanded and shaped to put on.  Still have 1 wing to build.  Does anyone have a close up shot of the wing trailing edge?  I'm wondering if i did the sheeting correctly as the top sheet overlaps the bottom sheet by like 1 1/2 inches at the tip.  Is it supposed to be this way, with the bottom sheet sanded at a angle to meet the top and then the top just overlaps that much?
Old 10-24-2011, 02:40 PM
  #1313
smoknrv4
smoknrv4's Avatar
Looks awesome, I got to get rid of some planes and start on mine!
Old 10-24-2011, 10:49 PM
  #1314
pedroglow
Jaroon01 Hello, my English is not very good and I use the google translator.
I think you mean the missile carrier when you ask me the scrim with Monokote in that area ......
I send you pictures, if that is not what you want to know, ask again, I try to help smooth
a greeting
Old 10-24-2011, 10:55 PM
  #1315
pedroglow
Now if
Old 10-24-2011, 11:09 PM
  #1316
pedroglow
more photos, if they will help someone ...
Old 10-25-2011, 11:44 AM
  #1317
pedroglow
have left these parts, someone could say to me that are .......?
Old 10-25-2011, 03:12 PM
  #1318
jaaron01
This is what I'm talking about. Is this correct? I've built several planes in my time, but this just seems flimsy to me. It this how its supposed to look prior to the missles?
ID:	1678690   Click image for larger version
Old 10-25-2011, 06:53 PM
  #1319
Quikturn
My Feedback: (12)
Quikturn's Avatar
Pedro,
You're doing a great job on your SU-27. I have an unstarted kit I bought about 1-2 years ago and this is making me want to build it this winter.
Old 10-25-2011, 10:35 PM
  #1320
pedroglow
If there is supposed missile carrier base
The thin pieces of balsa wood and I think I know where they are, but it is too late .... jajajaja, and the scrim!
thank you very much for your help
Old 10-25-2011, 10:38 PM
  #1321
pedroglow
Thank you very much friends!
Cheer up, is a very easy kit to assemble and flight should be fun
Old 10-27-2011, 05:49 AM
  #1322
pedroglow
more
auctions
For these pieces I've had to do by hand, because I had no worth as least 2mm hole and not have needed 1.8 or less, with 2mm thread escaped me
This is the appearance of depth and direction transmissions
Made for the cover recess
And how could der otherwise secured with pins hinges interns
Well, now if it looks good on her little, leg still do not know what I'm going to put forward, because I wanted to put a drag as the leading turbine jets ....
regards
Old 10-28-2011, 05:40 AM
  #1323
pedroglow
Bueeeeeeeno,pues esto se a acabado ya......
Con el tema de la pata delantera al final he hecho uin injerto ahi un poco raro,he soldado una vieja que tenía por ahi de 6mm de diámetro también.
No es de arrastre,pero le he dado una ligera inclinación ,siempre hará algo,además de esa manera queda totalmente guardado en la bodega una vez recogido el tren
Y este es al aspecto que tiene la criatura,el cockpit ya sé que así está muy soso,pero después del estreno,si todo vá bién y se lo merece,se le hará uno que se va a cagar la perra! :lol:
Faltarían solamente las tapas inferiores que cubren todos los servos de dirección de cola,pero no sé si hacerlo bien de fibra y resina o utilizar directamente el negativo que trae de plástico el kit y no camplicarme.....lo consultaré con la almoada :mrgreen:
Saludos
Old 10-28-2011, 01:27 PM
  #1324
jaaron01
I'm trying to see if this is correct or not. Has anyone else who built this plane remember the trailing edge wing tip having the top sheeting overhang like this? Just seems kinda weak to me. I've lost my CD, and the instructions don't really show this area.
Old 10-29-2011, 12:31 AM
  #1325
pedroglow
I'm traveling now, when I return on Wednesday, November 2 cd put the photos of that area of ​​the wing or if you prefer you can give me your mail and you send them.
