New Plane Bought At Toledo
My Feedback: (7)
RE: New Plane Bought At Toledo
C4F,
It does look like an LR-1, probably for the original Quarter Midget class with hot .15s.
A BSE .32 would be sweet, but beware of ending up nose-heavy. The racing .15s were very light. Most kits had long noses so they would balance.
Duane Gall
RCPRO
Duane Gall
RCPRO
NJ
Can you move the camera to the right on the last pic , ? The plane looks interesting and by the way nice find. I have a modeltech extra 300 .25-.36 on the way to the crib now ! cant wait to pull of a flawless knife edge.
P.S. crib = house.
P.S. crib = house.
My Feedback: (12)
SC
ORIGINAL: RC-FIEND
NJ
When I get it I will be knocking on your door for advice . I am sort of an agressive flyer , will the plane handle me as a pilot ?
My Feedback: (12)
SC
ORIGINAL: Razor-RCU
Aren't they heavy? (The Modeltech 300 I mean)
My Feedback: (12)
SC
ORIGINAL: RC-FIEND
NJ
Cool thanks Chuck, Mine is an ARF, so hopefully the seems will hold , You say 3.8 pounds is heavy , well I guess do to the size of plane. I will have to practice throttling down to land . I think this plane is on Real Flight g2 . I will get some practice in before madden.
My Feedback: (12)
SC
ORIGINAL: RC-FIEND
NJ
Sorry Crazy4flight , didn't mean to step on your post [&o] but Chuck I'm planning on using flapperon set up ,and I have been practicing with my trainer. What a difference flaps make for smooth landings . Once I get it I will start a build thread from out of the box to completion . Do you think I should invest in pivet point hinges ?
My Feedback: (12)
SC
I thought about adding flaperons but decided not to. The reasons included not wanting the extra weight and complexity. I also read mixed reviews about using flaperons on wings that didn't have straight trailing edges. If you're considering them to slow the landings down, I'd say don't bother. Get used to landing a bit fast, it'll be useful for other planes. The thing I like about this plane is it's not big and complicated. I've saved the bells and whistles (actually flaps, retracts, etc) for larger planes that can handle the weight better. I also just stuck with the CA hinges. They've been working fine. I'm sure something like pivot points would be better, but I didn't find them to be necessary. You could always start with the CA hinges and replace them if you find they don't work as well as you want.
One thing I definitely suggest is to not use the bolts they supplied for wheel axles. The threads chewed up the wheel hubs in a couple months. Replace them with bolt on axles. I also did not bother with the wheel pants.
My Feedback: (8)
NC
I picked up one of them also at the Toledo Show. I plan on putting a MAGNUM 36 that I have laying around in mine, with FMA 105 MG servos all around. The 8 oz tank they give with the kit is way to big for that plane, so I am putting in a 4 oz tank. Don't need a long run time when you are going that fast.
NJ
Thanks Chuck I will be talking to you soon. I think the plane already arrived, UPS left the notice. I agree about the size I was itching to get a small glow plane to mess around with for some time now. So here goes nothing . .
My Feedback: (12)
SC
ORIGINAL: magnumeng
Piper Chuck,
What servos are you using in your little Wild Hare? Thank you
Piper Chuck,
My Feedback: (12)
SC
ORIGINAL: Crazy4Flight
no it is spring
no it is spring
