Diamond Dust with O.S. .25 fx
FL
Im going to be using that combo along with a HS-81mg for throttle and Im looking for a tuned pipe. Went to Tower Hobbies and found [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXZ593&P=7]this MAC tuned pipe[/link] Will this work? Also what prop would be good for that combo. This is my first plane of this type and dont much about them
My Feedback: (19)
OH
RE: Diamond Dust with O.S. .25 fx
Hi there.......welcome!
Your dust will fly well with the .25 up front.
The mac pre-tuned pipe system for the OS .25 - .32 will work fine. Put an 8x6 or 9x5 prop out front, and let it turn up a bit (to start with).
Another option would be a JS30 jett-stream muffler. More compact, just bolts on to the engine - will gain over 1000-1500 on the top end. Cost about the same. Performance Specialties sells a similar UltraThrust muffler.
MI
pit_basher
Go to FlyingZhobbies.com and look for the mousse can muffler with macs header. It will do the same thing for about 30 bucks. My 25fx's on a stock muffler and 9x4 prop turn low 16's swap mufflers and it jumps to the middle 18's. Different props should yeild similar results.
Rick
Rick
