New plane, whatya think??
ON,
Hey guys, hows this plane look? Its got a 46" span and is 36" long. It has a os 25 in it. Looks pretty quick to me, any idea just how fast it might go? My guess would be in the 80's?
I'm pretty sure its a strega but I can't find any information on where it comes from or who made it?? Any information would be great
NJ
RE: New plane, whatya think??
Ok I love it but.... your pics are to large to actually look at the entire picture. I have heard of this plane but didn't know it came in a .25 size . Once I move I know for sure what plane I will purchase.
ORIGINAL: SpencerC
I think that if you bolt a mousse can to that .25, and slap on a 7x6 prop, it will do quite a bit more than 80... you may even top 100 (I'm being consevative here). Those .25's rev pretty good with a small enough prop.
Last year at the Eurocup (Club 20 racing) there was a guy using an OS .25... nobody noticed (it is "illegal"), because the engine was a "dog" compared to the real racing engines... but still his plane was moving nicely, especially when considering he was just using a sport engine. Nobody said anything about it, because the guy was clearly in it for the fun.
ON,
Do the flat plate tail surfaces hinder performance much?? Also, do you guys think its sleek enough to run a 7" diameter? I thought it would require at least an 8" to bite any air??
-edit- Then again, I really don't know what kind of prop a plane like this should be running, feel free to enlighten me
NH
I've read [link=http://homepage.mac.com/mikejames/nextcraft_site/aircraftdesignconcepts.html]here[/link] that for surfaces with chord less than about 5", flat plates work as well as anything else. If it was me, I wouldn't bother changing the tail for that reason. Anyway, [link=http://www.mh-aerotools.de/airfoils/linkage.htm]this guy[/link] claims a typical horizontal stab only makes 5% of the drag of the airframe, so if that's right you're not going to make great huge gains no matter what you do to that stab.
The plane looks really cool. How thick is the wing?
If it's not fast enough you can always get something from jett for it : )
My Feedback: (50)
I agree 8" is as short as I would go... I would put a Jett-40 and aluminum spinner on there right away-
That is one GOOD looking airplane! And retracts no less...
ON,
hehe you're not the only one Chris. I'll take more pictures to show you guys how thin the wing is etc. Any other estimates on speed? Do you think 80 would be conservative with the engine it has now?
My Feedback: (19)
OH
Looks like it has some plastic pieces - ARF type model. Correct ?? That is definately something that could still sell fairly well these days. People like Reno birds.
Nice aircraft though. Not sure who's kit/model it is. EZ use to make a few little racers like that a while back. May be one of those.
Fly it with an 8x6 out front at first until you learn about the plane and how it behaves. Afterwards you can drop down to a 7x6 and let the engine turn - but keep in mind the smaller prop will require a longer take-off roll, and will have less initial speed and rate-of-climb. Long flat climb, and a gentle first turn... then it will go like heck
ON,
Bingo, it plastic peices and does seem like it's an ARF. I thought it was a little EZ model too but couldn't find anything on the internet? Anyone have a link or pictures?
ON,
here are some more pictures, to give you an idea of how thick the fuse is, the prop is a 9x6. Also, how does the wing look? Seems pretty thin to me. What do you guys think I should use throw wise too?? I'm worried I'll put too much and it will be out of control and I am equally worried that I will not have enough throw...
Sure look nice, my guess about the speed would be around 100. Love the retracks, makes it look all grown up
Pink planes always fly the best
ORIGINAL: SpencerC
......the prop is a 9x6......how does the wing look? Seems pretty thin to me. What do you guys think I should use throw wise too??
NY
a quick measure from the pic puts wingthickness at 12.9 %
nice slim fuse, wind fillets ... looks like a nice clean design ... how much does it weigh ?
ON,
Also, the weight I guessed include the 1100MAH battery which I think probably adds quite a bit of weight. Would the plane still be fairly light at 3.5 pounds?
My Feedback: (50)
Yes, 3.5 lbs. is fairly light- what is the wing loading? I would use a smaller RX batt. pack anyways---
Does not look like an EZ bird, I had 2 of the Reno racers and they were different--
Looks *****in though!
ON,
hopefully sometime with weekend. Seems like it might have a nasty nosing over problem. Perhaps I'm not putting the CG at the right place. I tried to use a CG calculator but not sure I did the measurements right, it put the MAC at 9 inches from the root chrod and the CG 2.6 inches back from the leading edge. Am I way off?
NJ
Use the spar for the imaginary COG, using two fingers or a CG machine balance from this point. After you fly you can make adjustments accordingly. I'm starting to like a slighty tail heavy plane with the fuel tank empty being that I never land with the tank empty. GL
ON,
I would use the spar.. However the wing is not normal construction. I cannot detect a spar, it seems to be sheeted foam wing of some type.
