Kingcat 46, Pusher Propjet?
TX
RE: Kingcat 46, Pusher Propjet?
I don't remember where I found the picture of the first one...I think it's a scratchbuild. The other one I found in the jet forum... here's the thread: http://www.rcuniverse.com/forum/m_4394897/tm.htm
CA
Wow! [X(] I've been looking for my next big project. Bought the Bobcat XL plans and manual from BVM. Going to scale it down to a 90 size pusher prop.
Set up will be something like this
I've caught the speed bug. There is no hope for me now.
Thanks John,
Mods
Thanks John,
Mods
CA
ORIGINAL: Razor-RCU
Mods- Reminds me of the Comp-Arf Kangaroo that comes with a glow pusher mount... Keep us posted!
Mods
BC, CANADA
lol im looking for a 46 size one as well
o got a new la 46 laying around and figerd if i can get a 4 lbs one it would be kool
CA
Bigger.......
My Feedback: (50)
That is small... Mine is a couple feet bigger but leaks pretty badly [X(]
Your skills and attention to detail are among the best I have seen on here- Kit one of these and make a couple dollars
TX
Good luck Mods!
I found some information on the tomahawk elsewhere, if it'll help out. It sounds like a good addition to the speed forum...
Building: http://www.rcgroups.com/forums/showt...light=tomahawk
Maiden: http://www.rcgroups.com/forums/showt...light=tomahawk
CA
ORIGINAL: Razor-RCU
Your skills and attention to detail are among the best I have seen on here. Kit one of these and make a couple dollars
I'm working on the plans now in Autocad and Compufoil. I'll start a thread once I make some progress (and finish my other project: [link=http://www.rcuniverse.com/forum/m_4244427/mpage_5/key_/tm.htm]Highly Modified AKM SU-27[/link] ). Never can have too many projects .
Good luck Mods!
Mods
My Feedback: (19)
OH
I know Dub prepared two engines for similar projects about a year ago, two different builders. One was a Roo, was going to have a SJ-90L on it, the other was a BVM Bobcat, being converted to prop with a FIRE 50.
Both engines were setup as reverse-rotation engines - allows the use of a standard tractor prop. Opens up a lot more possibilities in the prop department.
I never heard much of anything back on either project.
CA
It has begun.....
Figure 1
Took a break form my other project (Highly Modified SU-27) and I'm happy to report that after a month of preliminary design, the pusher prop project has begun. It's still in the early CAD stages but I have the basic wing designed in Compufoil (figure 1) and exported the rib sketches to Soildworks 2005 (figure 2) to complete the final touches (landing gear, joiners, servos, etc).
Figure 2
Solidworks is a very powerful 3-D design program in which I can design everything down to the very last detail and once that is complete Solidworks can format all the parts in a laser cutter friendly format. It even can transform the 3-D design into 2-D drawings (for plans). I'll start a thread once I get a little further in the design process.
Specs
1. Power Plant: BSE Jett 95L Rear Exhaust (muffler routed through the fuse)
2. Weight: 8-9lbs
3. Wingspan: 50", fuse length: 60"
4. Spring Air 107 Retracts
5. 6 channels (standard four, retracts, and flaps)
6. Airfoil: NACA 0010 root to tip with 1 degree of washout
7. Balsa build-up wings with fiberglass fuse and twin booms
8. The engine will have a custom molded fiberglass cowl (trust me it'll work)
Mods
Figure 1
Figure 2
Specs
2. Weight: 8-9lbs
Mods
Hi Mods
Been wondering what you've been up to! (keepin an eye on your Su27)
After taking delivery on my AK Su 27...dont ask what the freight was from US-NZ your right shes a great kit, and I cant wait to get stuck in!
As for your new project...where do I sign!
Ants
Ants
CA
ORIGINAL: Ayrtonsenna
Hi Mods
Ants
Hi Mods
Ants
I'll kit this project once I get the bugs worked out and find a place that makes composite parts for an affordable price. I thought about making them myself but at breakneck speed I can only turn out about 5 fuselages a month. AK is very reliable and does great work for laser cutting so I'll probably have him do that.
Mods
CA
Started the thread over in the scratch builders forum. Check it out if you want.
[link=http://www.rcuniverse.com/forum/m_4588489/tm.htm]Kingcat-Like Thread[/link]
CA
Mods
Mods
I need your guidance, I'm so tempted to buy one of those Gas-Bobcat 50s, not a fan of ARFs but like you said..."for the Price, there a steal"
I'd be better to save my money and wait for yours right!!!???
Ants
Ants
CA
Mods
Ants
Mods
Ants
Mods
