Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
 Kobra with a Jett 46?? >
Old 02-12-2008, 07:27 PM
Default RE: Kobra with a Jett 46??
is this configuration hard to do? does the landing gesr has the same resistance(strenght of the original configuration?
thanks for all the help
Old 02-13-2008, 08:54 AM
This is not an easy mod to get right. If your not real handy at building you may want to not do this. If you have some skills you can figure it out. Good luck
Old 02-13-2008, 02:56 PM
i dont have very much expeirence on speed planes, so i wanted to know if the trike gear configuration will sacrifice too much speed.. or there is not really a difference?
sorry for asking too much.
Old 02-13-2008, 03:26 PM
I think their will be some, I took off the front gear because of Balance weight (using a 46 AX in a 25 size plane).
You could do the tri gear and use the OS32 and I'll bet it would be very close to the same in speed but that os is $$$$.
If you use the trike gear use a very narrow wheel like the MPI 1.86 size-Tower has them.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
