Patriot .40 Build
Old 11-08-2006, 11:05 AM
  #76
My Feedback: (10)
Ken Bryant's Avatar
Default RE: Patriot .40 Build
Since you already built one of these you alreadyt know that the nose is HEAVY. If you can manage it get as much to the rear as you can. I really wish I had installed retracts in mine. Problem is I got lazy and cheap... I'm still cheap so I guess mine will have to wait for a retrofit.
Old 11-10-2006, 02:05 AM
  #77
SmokinT,
Have you about got that plane done yet? Fingers are itchn& an twichin. I'll meet you over yonder, and will have us a shoot out! Give me a call!!
Later,
One wing low
ID:	557511   Click image for larger version
ID:	557512   Click image for larger version
Old 11-14-2006, 12:16 AM
  #78
Thanks hummingbird, buzz, Ken...I'm going to try to make it as light as possible. Have slowed down on building but here we go again:
Fun with cap strips...
ID:	559986   Click image for larger version
ID:	559987   Click image for larger version
ID:	559988   Click image for larger version
Old 11-14-2006, 12:19 AM
  #79
Despite trying to weigh everything as the wings were built, the right wing is 7% heavier than the left wing! Oh well...
ID:	559994   Click image for larger version
Old 11-14-2006, 12:21 AM
  #80
The joining of the wings, and the discovery of a problem...
ID:	560006   Click image for larger version
ID:	560007   Click image for larger version
ID:	560008   Click image for larger version
ID:	560009   Click image for larger version
ID:	560010   Click image for larger version
ID:	560011   Click image for larger version
ID:	560012   Click image for larger version
Old 11-14-2006, 12:26 AM
  #81
Despite using the included dihedral gauge on both root ribs...
ID:	560019   Click image for larger version
Old 11-14-2006, 12:31 AM
  #82
If you follow the instructions, then this is what you get...
ID:	560030   Click image for larger version
ID:	560031   Click image for larger version
ID:	560032   Click image for larger version
ID:	560033   Click image for larger version
Old 11-14-2006, 12:34 AM
  #83
I can't sand that gap out, it's just too big. If you block up the tip just ~ 1/2" (instead of 1 1/8"), the fit of the root ribs is a lot better...
ID:	560035   Click image for larger version
ID:	560036   Click image for larger version
ID:	560037   Click image for larger version
Old 11-14-2006, 12:37 AM
  #84
Here is how the bottom gap looks comparing the 1 1/8" vs 1/2"...
ID:	560039   Click image for larger version
Old 11-14-2006, 12:40 AM
  #85
I think I ran into this with my first Patriot. I just glued it together as was; it flew fine (by my standards!). Unless someone has a better idea, I think I'm just gluing it together at 1/2". I'm not real worried about roll-coupling, etc. I'm just worried about going fast. Really fast.
Old 11-14-2006, 12:42 AM
  #86
How the glued center brace fits, just fine...
ID:	560045   Click image for larger version
ID:	560046   Click image for larger version
ID:	560047   Click image for larger version
Old 11-14-2006, 09:15 AM
  #87
Smoking that is no problem, just cut and glue a thin piece of balsa 1/16" to the end rib of each wing and sand to fit. This will give you some extra wood to get the joint right. I wouldn't want that much epoxy in that joint because it will add too much weight. However, I am with you I would just lower the dihedral till the joint matched and glue her together. Yo probally won't even notice it.
Old 11-15-2006, 05:51 PM
  #88
Smokin, I have seen a Patriot fly that had the wings clipped a little. I am not saying that I would do that but the guys plane was much faster than mine and he had flown it for over 10 years with an OS VFR 46 that he had installed a ducted fan sleve in. This plane will head toward the ground if the engine quits anyway. I have head a couple of deadsticks with mine and was able to get her in but luckily I had some altitude.
Old 11-16-2006, 01:40 AM
  #89
Hey Buzz,
I didn't think of shimming up the center ribs with scrap balsa and then sanding but that's a good idea. I just went ahead and glued them up with less dihedral. Hopefully will make for easier inverted flight . I worked a little on the wing tips for later and am also going to start the tail feathers soon. I need to get some serious progress done this weekend.
How did your friend clip his Patriot's wings? Did he just shorten it by a rib or two? I think I'm going to clip the ailerons some but I think I'll leave the span as is...
ID:	561184   Click image for larger version
ID:	561185   Click image for larger version
ID:	561186   Click image for larger version
ID:	561187   Click image for larger version
ID:	561188   Click image for larger version
ID:	561189   Click image for larger version
Old 11-16-2006, 12:19 PM
  #90
I think he took off the last rib and installed the wing tip. I landed well and flew very good.. He also used the plyon pizza cutter wheels.
Old 11-21-2006, 03:06 AM
  #91
Finishing the top center section sheeting after joining the wings...
ID:	564187   Click image for larger version
ID:	564188   Click image for larger version
ID:	564189   Click image for larger version
Old 11-21-2006, 03:08 AM
  #92
Filling in the gap from the dihedral...
ID:	564191   Click image for larger version
ID:	564192   Click image for larger version
Old 11-21-2006, 03:10 AM
  #93
The center block...
ID:	564194   Click image for larger version
ID:	564195   Click image for larger version
Old 11-21-2006, 03:13 AM
  #94
Working on the aileron control horn blocks and bearings. I know there are better ways than torque rods but I'd like to keep everything inside and minimize drag...
ID:	564197   Click image for larger version
ID:	564198   Click image for larger version
ID:	564199   Click image for larger version
ID:	564200   Click image for larger version
Old 11-21-2006, 03:18 AM
  #95
Fiberglassing the center section with thin CA. This works great and adds little weight but be sure you do this where there is a breeze, this much CA will do more than clear the sinuses. Also a good idea to wear a mask when sanding fiberglass...
ID:	564202   Click image for larger version
ID:	564203   Click image for larger version
ID:	564204   Click image for larger version
ID:	564205   Click image for larger version
ID:	564206   Click image for larger version
ID:	564207   Click image for larger version
ID:	564208   Click image for larger version
Old 11-21-2006, 03:20 AM
  #96
Well, the building has been slow recently and my motivation has been marginal. Then this showed up on the doorstep today...
Old 11-21-2006, 03:23 AM
  #97
At proptop's suggestion I ordered this little motor ...
ID:	564211   Click image for larger version
ID:	564212   Click image for larger version
Old 11-21-2006, 03:28 AM
  #98
It's not the BSE Signature Series but it still looks great and the man himself still signed it
Old 11-21-2006, 03:31 AM
  #99
A few more for your viewing pleasure...
ID:	564215   Click image for larger version
ID:	564216   Click image for larger version
ID:	564217   Click image for larger version
ID:	564218   Click image for larger version
ID:	564219   Click image for larger version
ID:	564220   Click image for larger version
ID:	564221   Click image for larger version
Old 11-21-2006, 03:36 AM
  #100
I have a couple of older SJ .46 motors that I bought a few years back to go into a Pica Duellist. Here are some comparison shots of the .60LX and the .46 as well as their respective mufflers...
ID:	564228   Click image for larger version
ID:	564229   Click image for larger version
ID:	564230   Click image for larger version
ID:	564231   Click image for larger version
ID:	564232   Click image for larger version
ID:	564233   Click image for larger version
ID:	564234   Click image for larger version
ID:	564236   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
