kyosho Kelly F-1
#401
RE: kyosho Kelly F-1
Do I see a new thread here?
It looks like there is some interest in the NXT. Someone needs to start an NXTthread, since some have made their way to the good ole US of A.
I only say this because I need to convince myself that I need one for my ducted fan engine, purely selfish motivation here!!
#403
#404
well a good prop to find is also an issue for me...some guys use 10x10 APC boiling them in hot water for a couple of minutes to make them ready for 20 K RPM..... I guess I want a Carbon prop...just need to find one
I will put a 500 ml tank so I will have 4 to 5 min flying time at full throttle...moderate flying style should give me an extra min for one or two landing attempts
Keep you posted on that project
Cheers
Cheers
#405
Thanks for the prop tip. I need to keep the pitch around 8.5 or so for a target speed of 155 + -. The Toni is a little chunky around the middle, and I do not think it will go much faster than that. How well does the boiling trick work? That would be great if it did, even if they were only good for a few flights.
For your plane, I believeeither ZZ proips orEliminator makes a 9x10 in carbon for around 16 bucks. That should scoot on a slippery plane.
