Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
(Something Fast?) Delta Build Thread
Old 12-18-2012, 05:27 AM
  #601
Fanni0124
Default RE: (Something Fast?) Delta Build Thread
Screamin Demon am I doing.
Question.The aircraft's center of gravity where it is?
Thank you for your response.
Regards: Balázs Bundik
Old 12-18-2012, 08:26 AM
  #602
iron eagel
iron eagel's Avatar
The COG is the center of the forward spar on the plans.
Old 12-18-2012, 09:30 AM
  #603
MJD
MJD's Avatar
At least when he asked on three different threads he got the same answer each time. That's not always true on RCU..
Old 12-18-2012, 10:48 AM
  #604
iron eagel
iron eagel's Avatar
LOL, your right Mike sadly that is so true...
So are there going to be future runs of the SD?
I understand your modeling efforts have been sidelined because of your work, your .65 version looks pretty sweet by the way.
I should have some progress to post on my electric version shortly.
Old 12-18-2012, 11:04 AM
  #605
MJD
MJD's Avatar
Yes, but I am so freaking far behind it is embarrassing. I booked two weeks off work over the Xmas holidays - my first long break in 3 years - and the goal is to get some parts made and make the drive to the balsa and laser cutting supplier. This is where I should have been in September..
The .65 looks cool, it's a ***** to fly but I started getting used to it before winter struck. If I get my act together and build a twin rail delta launcher this winter I might actually look forward to flying it rather than fearing the hand launch.
I have to get the .15-.25 version on line too. It flies sweetly and would be a perfect lekkie convert, 400-800W (yeah yeah, or more ) on a 3S 2100 or so. Need some advice on the best way to design the motor mount to be builder friendly for electric.. I'm a dweeb with electrics and don't know the best configuration for the masses. Firewall rather than nose ring mounting would be easier on a ply/balsa kit like this.
Old 12-18-2012, 01:08 PM
  #606
iron eagel
iron eagel's Avatar
Mike I have been building them so the motor mount is forward of the motor. I think you have seen my PQ Stingray and SD builds take a look at what I did for the forward engine mounts for electrics.
The launcher takes a lot of stress out of getting the airborne.
I am thinking of doing one up for a Neu motor with a bit larger setup to accommodate the larger diameter motor, something like the 1521 on 6 cells.
Old 06-02-2013, 07:07 AM
  #607
Fanni0124
Respected Modelers! Diamond Dust electric I'm building. what electric motor
do it, what regulatory, what battery?
Old 01-09-2014, 01:49 PM
  #608
Fanni0124
Default Electric
Electric motor: Turnigy 1450 kv
Esc:Turnigy trust 70A Battery: Turnigy nano-techs 4s 2200 mAh
ID:	1955778   Click image for larger version
ID:	1955779   Click image for larger version
ID:	1955780   Click image for larger version
ID:	1955781   Click image for larger version
ID:	1955782   Click image for larger version
Old 01-09-2014, 03:49 PM
  #609
combatpigg
combatpigg's Avatar
Nice job Fanni..!
You've got enough power to have a very impressive airplane.
Good luck with it.
Old 01-18-2014, 09:06 AM
  #610
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Originally Posted by combatpigg View Post
Many years ago when I first discovered this forum there were a lot of Diamond Dust threads.
I wanted to build one, so it was a simple matter to find out the basic dimensions and I built my own.
Mine differed from the original with the way I built the engine mount and the center section to house the fuel tank and radio gear.....but at any rate it flew just fine.
The "airfoil" isn't critical, just keep it the same thickness as the original and you will be OK.
The original Diamond Dust airfoil with 4 flat sides did the job with the sag of the covering material forming the actual airfoil between the 2 ribs.
I see you are still sharing wisdom in here, how have you been?
Old 02-01-2014, 10:14 AM
  #611
Fanni0124
Default Delta
The take-off in a video
http://youtu.be/QCmKdx6mROw
Old 02-01-2014, 10:21 AM
  #612
iron eagel
iron eagel's Avatar
Glad to see you got it airborne, good luck with it.
Old 02-16-2014, 01:41 PM
  #613
pabrokenprop
is anyone selling these kits? or anything like the diamond dust? any link will be greatly appreciated.
thanks
Old 02-16-2014, 02:14 PM
  #614
iron eagel
iron eagel's Avatar
thanks
Send a PM to MJD he is the one who took over the production of them. He may be getting to the point of actually doing another run of them.
This is the one I just finished.
Old 02-16-2014, 04:29 PM
  #615
MJD
MJD's Avatar
In late December I bought a small laser cutter, big enough (just!) to do the SD kits myself. Before that I used outside services, but I got tired of that. I am still on the learning curve on the cutter, but hope to be functional on it soon. So there is hope production will resume in the foreseeable future..
Old 02-16-2014, 05:18 PM
  #616
pabrokenprop
MJD
thanks for the reply personally.. please PM me if you are able to get "the bugs out" is your kit nitro or electric or both? I have my .46vxdf from my DD that got fuel soaked.
thanks again
Nick
Old 02-16-2014, 06:06 PM
  #617
MJD
MJD's Avatar
It's similar to the DD - designed for .40 sized engines. It is a bit faster due to the thinner wing. Also flies great on .32/.35 engines. They have been flown variety of engines, including Nelson FAI .40, OPS Speed .65, OS .77 VR-DF. A good strong .45-.50 will get you going like a bat out of you know where and with a light wing loading. Your OS will work great, though you'll need an appropriate prop (no kidding, but you know what I mean!).
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
