Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
 CERMARK F-18 HORNET, BUILT IT BETTER, STRONGER, AND FASTER! >
Old 04-25-2014, 12:54 PM
  #276
My Feedback: (13)
could someone provide me with the control throws for the cermark F-18. thank you james smith
Old 04-25-2014, 08:19 PM
  #277
From the Cermark F-18P manual..
SETTING THE CONTROL THROWS
Use the following control travels as a starting point
Ailerons: LOW RATE = 5/8 up and down, HIGH = 7/8
Stabilators (elevators): LOW RATE = 3/4 up and down (at the trailing edge), HIGH = 1
Rudders: 3/4 left and right
I don't remember what I used, but it was probably close to the above. I also used some exponential to make it less touchy around neutral. And, make sure it isn't tail heavy..
Old 04-25-2014, 08:48 PM
  #278
This is what you get when it's tail heavy ...
Old 04-25-2014, 10:22 PM
  #279
I repaired the nose by taping it all back together and adding a layer of glass cloth and epoxy to the inside. I also replaced the O.S. .61 with a Magnum .91 and a Jett muffler..
http://youtu.be/91RVu5MMCP8
ID:	1990006   Click image for larger version
ID:	1990007   Click image for larger version
ID:	1990008   Click image for larger version
Old 04-26-2014, 12:36 PM
  #280
My Feedback: (13)
Ailerons: LOW RATE = 5/8” up and down, HIGH = 7/8”
Stabilators (elevators): LOW RATE = 3/4” up and down (at the trailing edge), HIGH = 1”
Rudders: 3/4” left and right
thank you
james smith
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
