Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
OUTLAW from EXTREME FLIGHT
Old 02-11-2008, 11:25 PM
  #51
freakingfast
Default RE: OUTLAW from EXTREME FLIGHT
119 and 190 could sound the same on a PA system.
Or the announcer mis-heard the specs.
Old 02-12-2008, 12:28 AM
  #52
evan-RCU
evan-RCU's Avatar
125mph level is about what they fly with a OS.32, full pipe, 8x8 APC...
Old 02-12-2008, 01:32 AM
  #53
freakingfast
125mph sounds about right. I much prefer the APC 9X6 over 8X8. The top speed is a bit more with the 8X8 but takes seems to take a city block to get there. Return to speed after maneuvers is almost instantaneous with the 9X6 with perhaps a 5 mph penalty. The Outlaw has a thick airfoil and I always ended up going back to a 9" disc area prop with the three engines I've used (Webra speed 35 Ringed, OS 32 and TT 39 heli modified).
Old 02-12-2008, 03:30 PM
  #54
Strykaas
Claiming the os 32 is more powerful than the OS is quite surprising. Did you actually use both ? The Webra .32 is lighter than the OS anyway.
Old 02-12-2008, 04:09 PM
  #55
evan-RCU
evan-RCU's Avatar
Outlaw nose.... on the outlaws they are not turnd around. I do cut off the needle valve so it dosn't hit. I have the carb flipped on a fun fly though.
ID:	876943   Click image for larger version
ID:	876944   Click image for larger version
Old 02-12-2008, 05:10 PM
  #56
Strykaas
Thanks for the pix
I thought you had the webra .32 on it
Old 02-12-2008, 05:42 PM
  #57
evan-RCU
evan-RCU's Avatar
Sorry, I don't have any Webraon anything right now unless you consider the Magnum which is a modified speed .50.
Old 02-12-2008, 08:52 PM
  #58
freakingfast
ORIGINAL: evan-RCU
Good point Evan.
I had forgoten about the remote needle, mine had broken off from another mishap and when I used the OS 32 on the Outlaw I tucked it out of the way like you did.
The needle on the TT39 (now on the Outlaw) sticks down lower than like. My front skid helps protect it.
Webra 35 is shown in the picture.
Old 02-13-2008, 03:09 PM
  #59
Strykaas
OK I was told again today Outlaws are coming in next week. Larry, any input ?
Old 02-15-2008, 01:41 PM
  #60
wttiger42
I called extreme flight yesterday and ordered mine. They told me the container was in atlanta and they would be getting it today (2-15) and should start shipping them on monday.
Old 02-15-2008, 04:56 PM
  #61
Strykaas
Thanks a lot wttiger42, that sounds pretty compatible with the delay announced by my LHS . I'm looking forward to your review.
Old 02-15-2008, 08:55 PM
  #62
MustangAce
MustangAce's Avatar
Anyone know what the Red(Orange) scheme really looks like? On Bottom too??????????????????
Old 02-15-2008, 10:20 PM
  #63
wttiger42
I have no idea. I ordered that color scheme though.
Old 02-20-2008, 08:02 PM
  #64
Rocketman612
My Feedback: (84)
Rocketman612's Avatar
Ordered the Orange,Black version. Should be sweet[8D]
Pete
Old 02-20-2008, 08:07 PM
  #65
wttiger42
I received my tracking # by email today. My outlaw should be here soon !
Old 02-20-2008, 10:29 PM
  #66
badazzbusa
http://www3.towerhobbies.com/cgi-bin...?&I=LXBY43&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXZ607&P=M
http://www3.towerhobbies.com/cgi-bin...?&I=LXZ558&P=M
Would this be a good combo for the Outlaw or should I just run the stock muffler for starters or get the Macs black one piece pipe?
Thanks for any help, I've never ran a pipe on a plane before but have tuned them on boats a few years back.
Old 02-20-2008, 10:35 PM
  #67
evan-RCU
evan-RCU's Avatar
Good combo that's what I have now on mine. I started with mousse cans but now have the OS and pipe you have in the links. You'll have to shorten the header about 2 inches to get it on the pipe with a 8x8 and put the pressure tap on the header not the pipe.
Old 02-20-2008, 10:36 PM
  #68
wttiger42
Should be ok. Ive used a similar combo before.
Ive ordered the webra .32 and header pipe. I plan on building a mousse can muffler.
Old 02-20-2008, 11:10 PM
  #69
MustangAce
MustangAce's Avatar
Jett .35 BSE for me
Old 02-21-2008, 01:52 AM
  #70
freakingfast
ORIGINAL: badazzbusa
I have never seen any performance gains using the Macs BLACK one piece MUFFLER, it's a very good replacment for a lost or damaged stock muffler. High performance tuned/muffled pipe & header kit for an OS 32FX is the Macs pre- tuned pipe #1910 ($89.95) http://www.macspro.com/pretunedsystem.asp Use with a 9X6 APC sport prop.
A Jett stream or Ultra Thrust TUNED mufflers are also very good.
It's best to break the engine in with the stock muffler first. Run it fast (wide open) but rich two cycle.
This is what the pipe looks like mounted
The extra long blue coupling is my launch handle
Old 02-21-2008, 08:42 AM
  #71
badazzbusa
Thanks guys. I'll order it today.
Old 02-21-2008, 05:01 PM
  #72
Strykaas
OKAY.
I have two NIB Webra .32 at hand. I think I'll use one of them instead of my magnum. One of them has the lightweight stock muffler (not baffled [X(]). How much performance gain is to be expected from the mousse can muffler setup pictured on ExtremeFlight web site ? And does anyone know how to build that kind of setup ? Where does the header stop ? Where does the stinger start ? I've read several articles about them but never tried it. I already have the .32 sized macs header btw. I have the bad feeling the whole thing would come apart after some flight time ... this mousse can muffler has reportedly to be mounted "free".... which wouldn't be the case for a traditional tuned pipe, which I think would be more durable. Any thoughts ?
My servos setup : 3 x HS 645 MG. Is it OK for all out performance ?
Intended prop : 8x8. Can I break-in that webra on the ground with a 8x6 ? Good ol' 2' pitch rule. (pretty scary idea as I regularly run my os 15 LA on this prop [X(]).
Old 02-22-2008, 10:38 PM
  #73
wttiger42
My Outlaw came in today. Excellent packaging. I cant wait to have it in the air.
Plane looks awesome in person.
Old 02-22-2008, 10:45 PM
  #74
MustangAce
MustangAce's Avatar
Got my hands on mine as well. More ARF perfection from Extreme Flight.
Extreme Flight has set the benchmark for RC aviation.
Old 02-23-2008, 05:55 AM
  #75
Strykaas
STOP TEASING ! WE NEED PICTURES AND CLOSE UPS !
