Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
new design: Strega 45
Old 03-24-2008, 08:37 AM
  #51
look
Default RE: new design: Strega 45
You can order an OPS with me. With open pipe or muffled tuned pipe.
They are back in production on request.
Old 03-24-2008, 08:56 AM
  #52
look
Mold parts painted. Soon I can start with the last part of molding.
The paint has to dry for 24 hours and the plug has to be waxed five times.
Now I can start building the wing and stab and making the building instructions with pictures.
Old 03-24-2008, 09:45 AM
  #53
look
The belly pan mold has been waxed 5 times and put in a gelcoat.
Tomorrow I will make the first belly pan.
I have started glueing the leading edges and waxing the fuse plug.
Old 03-24-2008, 10:58 AM
  #54
look
Glueing the leading edge with Elmers white, shaping with a razorblade tool, sanding with a block in the airfoil contour and final fine sanding with a piece of sandpaper 150 gritt pulling on the ends and make the LE with a nice rounding following the airfoil.
Do not make the LE sharp.
ID:	912181   Click image for larger version
ID:	912182   Click image for larger version
ID:	912183   Click image for larger version
Old 03-24-2008, 11:01 AM
  #55
look
Now I will have to make the routing files for the wing and stab tips und cut the tips.
The middle part of the wingtip is thin plywood and on both sides it is balsa.
More tomorrow.
Old 03-24-2008, 03:06 PM
  #56
izzy
look
can you tell us how the wing will be supplied
will it be sheeted with leading edge and tip already glued?
what will be left to do ?
how much is the ops 60 with pipe etc , and does anyone know how it compares to the Jett 60L FIRE engine
Old 03-24-2008, 03:55 PM
  #57
look
Izzy,
I will make a deluxe kit with glued, shaped and sanded leading edge and tips and a basic kit where you can do this yourself.
You will have to glue the wing together, glue in the wingspar, glue in the servo plate. Glue in the firewall, stab and servomount.
The plywood for the wingbolts have to be glued and the bolts for the bellypan has to be mounted. Ailerons are complete ready for use. Glue the cnc controlhorns in the ailerons and elevator. All parts are cnc cut. Price of an OPS can I tell you later.
Difference between Jett and OPS can I not tell you. The wingspar, servo's, ailerons and retracts are cnc cut out of the wing.
Regards,
Look.
Old 03-24-2008, 04:48 PM
  #58
MJD
MJD's Avatar
ORIGINAL: look
Any idea of the cost? This is the 5 port, rear intake, rear exhaust engine, right?
Old 03-25-2008, 03:07 AM
  #59
YUKONFLYR
YUKONFLYR's Avatar
ORIGINAL: look
Same here! Would like to know the cost and availibility
Old 03-25-2008, 05:31 AM
  #60
look
The LE glued to the wings:
Old 03-25-2008, 05:32 AM
  #61
look
The first mold has been used to make a belly pan from glass and carbon roovings:
ID:	912996   Click image for larger version
Old 03-25-2008, 05:57 AM
  #62
look
Here are some prices from OPS.
The engines are in production and we are waiting for a delivery.
57851040 SPA RCA + 574920 175,00 40FIRE with pipe open
57856040 SLP RCA 165,00 40 engine front intake
57857040 SLP RCB 175,00 40 engine
57858040 SLP Pylon 165,00 40 pylon engine and pipe
57867040 SPP RCB + 574920 195,00 40 RIRE pipe open
57868040 SPP Pyl. + 574920 195,00 40 pylon engine + reso open
57869040 SPP VAE + pipa 165,00 40 speedengine with pipe open
10ccm SPP VAE RC 280,00 60 speedengine with carb. and pipe
SPP means rear intake and rear exhaust
VAE means speed engine
574920 is tuned pipe open
prices in Euro without shipping costs.
Old 03-25-2008, 06:02 AM
  #63
HaveBlue
HaveBlue's Avatar
thanks for posting those engine prices, I too have been following this thread with great interest, the strega looks fantastic, very nice job indeed.. i think one of those OPS speed engines is a "must have" item..[sm=thumbs_up.gif]
Old 03-25-2008, 06:51 AM
  #64
look
Thank you ! I am glad you like this thread.
Later I will cut the wing and stab tips with the router.
Look.
Old 03-25-2008, 09:51 AM
  #65
look
Wing tips 8mm balsa on top, 0,6mm plywood in the middle and 6mm balsa.
Stab tips 2x 5mm and plywood 0,4mm in the middle:
ID:	913079   Click image for larger version
Old 03-25-2008, 09:54 AM
  #66
look
I will glue them together with 24 hours epoxy.
So tomorrow they can be glued on the wing and stab.
In the mean time I can work further on the last side of the fuse mold.
Old 03-25-2008, 10:58 AM
  #67
look
The tips are glued with epoxy:
ID:	913134   Click image for larger version
ID:	913135   Click image for larger version
ID:	913136   Click image for larger version
Old 03-25-2008, 11:55 AM
  #68
YUKONFLYR
YUKONFLYR's Avatar
ORIGINAL: look
Thank you
Is OPS going back into full production or is this a limited run?
Old 03-25-2008, 02:45 PM
  #69
look
It will be full production.
They had sold the molds for the engines and recently they bought it back.
Old 03-26-2008, 05:27 AM
  #70
look
The abachi (obeechi) leading edges are sanded:
ID:	913871   Click image for larger version
Old 03-26-2008, 05:29 AM
  #71
look
The bolts are out of the belly pan mold:
Old 03-26-2008, 05:31 AM
  #72
look
The first belly pan (engine and exhaust cover) is ready from glass and carbon strings:
ID:	913875   Click image for larger version
Old 03-26-2008, 05:35 AM
  #73
look
Sand the wing 90 degrees on a flat underground with a block before glueing the wingtips with Elmers white.
Use rubber bands to hold 4 wooden paint sticks:
ID:	913877   Click image for larger version
ID:	913878   Click image for larger version
Old 03-26-2008, 05:38 AM
  #74
look
Glue the wingtips, keep the plywood in the middle of the LE and TE by moving the stick forward or backwards:
ID:	913880   Click image for larger version
ID:	913881   Click image for larger version
Old 03-26-2008, 05:41 AM
  #75
look
The mold parts are waxed and glued in place.
Now it is time to finish the fuse mold:
