H9 Jackal 50 Prop Jet
#103
RE: H9 Jackal 50 Prop Jet
the 56 is an animal............if you try to order the 60LX, Dub will inform you that he is building you a 56. for some reason the website is not updated yet, but Bob will also give you every tip on running the new engine. great customer support i call it
my 56 is still on the breakin run with 1 gallon run thru it now, but is turning a 9x8apc at 18,400 peaked. the torque that this engine produces turns the 9x8 like it's just a toothpick. this airplane should really scream with this combo.
[/quote]
thats the one im going with.. looking forward to get this project going...
#104
ORIGINAL: summerwind
Dave,
buying them aftermarket is always an option, but we both know the hazards of cutting Carbon Fiber.
it isn't hard to do with the right equipment either.
we also know how much weight was saved just on the wing tube alone with our SD's right?
it would be better to include these items in the kits now even it adds a few more bucks to the kit. it shouldn't be much though, but would surely save at least a 1/4 lb, and be much stronger to boot.
Dave,
i found these... maybe the way i go..
for the tail=
Rigid Carbon Fiber Shape Round Tube, .312" OD, .236" ID, 48" Length |
In stock at $25.80 Each |
for the wing=
DragonPlate Carbon Tube ~ .750"OD x .540"ID x 24"
http://dragonplate.com/ecart/product...ID=744&cID=102
$26.95
#105
My Feedback: (20)
NY
ORIGINAL: robbyvaughn9
Is a 9" disc enough for the Jack? I wonder what kind of RPMs that motor would achieve with a 10x7ish propeller?
#106
ORIGINAL: _Tommy D
Is a 9'' disc enough for the Jack? I wonder what kind of RPMs that motor would achieve with a 10x7ish propeller?
i had my 56 on a Sundowner, and the 9x8 turned it into an animal.
i think it lands slower with a 10 inch disc, but the 9 inch prop pulled the 6 lb SD straight up with acceleration.
#107
it'll turn a 10x7 without a doubt.........depends on what happens in the air.
ORIGINAL: _Tommy D
The jackal will weigh in closer to 9 lbs when completed, closer to that of the Cermark f16 prop jets. Can we expect the 56 to perform as well with this weight? I do agree about the 56 on a sundowner, I've seen it myself..but not sure about the performance of the 56 on the jackal...i think I will go with the 90LX with an 11x8 prop. This turns 16K for me on the bench.....either way I will wait until others have ventured and report back before I act...
For the record, I have the 56 on my weston magnum...unbelievable (18600 with 9x8 APC)...but the magnum is a very light airframe...
#109
ON, CANADA
My patriot XL weighed 9lbs and and my Jett 90L flew it with authority, if this thing is 9lbs a 90 would be what I'd be using, my Juno F-20 I'm flying right now weighs 5lbs and I use a Jett60LX in it w/ a apc 9X8 and love it, but I don't know about the 56 in a 9lb airframe geesh.[:-]
#110
ORIGINAL: smoknrv4
#112
My Feedback: (14)
RI
im new to retracts so what would be the better for this plane Pneumatic are Mechanical
#113
as far as the engine i ordered a jett 56lx today... i hope i didnt make a mistake??? in the video they have a Evolution .60NX seems to be doing good... we know how videos can be... im sure the jett will put out alot more the than the .60nx . so maybe it will be fast.. im new to nitro so help is much needed.. i do want to go fast !!!!!!!
so with the 56lx what prop should i look to be running ??? i seen 9x8so will that be big enough ????
now the retracts.... i want be flying with fixed gear.. so when the jackal comes in then i gess i will go from there.. i was looking to go with the robarts Progressive Pneumatic.. if they are not out looks like it maybe the e-flite... what about these... will this work ?
http://www.hobbycity.com/hobbycity/s...idProduct=7996
http://www.robart.com/products/pneum...ists-605hd-607
thanks for all the help....
robby
robby
#115
so with the 56lx what prop should i look to be running ??? i seen 9x8 so will that be big enough ????
robby
robby
#116
the note that Dub sent with my 56 was to start with 10x6, 9x8, 9x9.
the info Bob27 gave me when i first inquired about the 56 was that this engine is a long rod version and packs more torque along with the rpms of it's previous model.
he wasn't kidding about the torque either. with a 9x8 it punches out of the hole like "right now" and it still looks like there is more to get as after breakin it is now spinning the 9x8 at 18,400 in a Sundowner installation that includes a spacer between the pipe and engine of which Bob has posted will cost a couple hundred rpm.
in regards to a previous post about using the 90LX, i was thinking the same, but it will add 8 ounces more to the nose in this plane...........if everyone thinks the Jackal will come out to 9lbs with the small block engine, think of where it will end up with another 8 ounces in the nose and whatever weight it will take to balance. i want to fly and enjoy this plane, not be on pins and needles when trying to land it.
#117
good post..
#118
My Feedback: (81)
Ordered all my stuff for mine today...Got the electric retracts from Eflite. Gonna try em out on this bird. Gonna keep everything in the box un opened incase this plane gets pushed back to 2012, by then the world will be over and I will just need my credit from Horizon. LMAO
#119
ORIGINAL: Dblex
As far as I know the MN 48 are not being sold here in europe
I was thinking HS-225 but not trusting them on this application. Any other ideas?
#120
My Feedback: (66)
ORIGINAL: vasek
I wonder what substitution could work for the MN 48 mini-servo?
ORIGINAL: Dblex
#121
Bill,
can you tell me if a 2.625" x 5.5" round tank will fit in the tank area?
Bill,
was anyone able to find out what kind of tank will fit ???
im looking to go with a Bubbleless Fuel Tank........
thanks robby
#122
ORIGINAL: Dblex
Which retract size did you order . Any idea if mods are required ?
#123
if i had to gess it would be these....................
http://www.horizonhobby.com/Products...ProdID=EFLG430
#124
I ordered a set of these for the Phoenix7 but thats a bigger plane , I think they may be a little heavy for this one .
You might have to do a little calculation here.
#125
ORIGINAL: kqutob
how about these...
http://www.e-fliterc.com/Products/De...ProdID=EFLG230
