Q40 Racer!
1 Attachment(s)
Just picked this up on a trade, looks like a candidate for my OS .46VRDF. Not sure what it is, hopefully Ed Smith can help me out on that one.:D
RE: Q40 Racer!
It says "Sattlers Panther" on the nose. Harold Sattler is the guy for Q40's in Canada with several designs over the years. I'm guessing its a Panther, but not sure I've ever heard of one. It is definately one of Ed's old planes, I believe that is his companies name on the side "avia tool design".
RE: Q40 Racer!
Nice find,Looks a sleak little beast. Exhaust exit under fuz for 46vrdf??
RE: Q40 Racer!
It's Harold Sattler's FAI pylon design from the 90's. The NACA duct on the top of the nose tells me it was set up for the rear intake engines that were used up through the late 90's. I think all the Canadians flew them at the 97 & 99 World Champs, which Ed was a member on.
RE: Q40 Racer!
Yes the exhaust exits under the fuse, and I did a mock fit with the 46vrdf engine w/ rear intake and it looks like its going to fit.
RE: Q40 Racer!
I know this plane is probably not a big deal to some of you vet pylon racers....and I know it should go in the pylon forum, but its exciting for me to finally get my hands on one of these that I could afford, and this is where I hang out, I just hope it all pans out.:D
RE: Q40 Racer!
Awesome find SRV! I would feel the same way you do. Get that thing going and enjoy it.
Heck put a TT.40 in it and you can race with DaveN :D |
RE: Q40 Racer!
Lets see that vrdf on it ripping the sky up. :DFreakinfast knows alot about that engine and good props for it.
RE: Q40 Racer!
The only thing I need is a header, I have a pipe and a bunch of APC q40 carbon props (7.4x8.25) squirreled away that were just waiting for this type of air frame to come along.[sm=thumbs_up.gif]
So once I get a header for the engine, I will do some bench running for breakin and tuning. |
RE: Q40 Racer!
1 Attachment(s)
Freaking fast did a thread on the 46VX-DF, (which I have saved in my subscribed threads)...but this is the VR-DF, so I would imagine the performance is lacking a little in comparison, but I'm wondering how close it is with prop sizes and type of header pipe set-up etc...Freaking Fast could you maybe shed some light on this? I'm really pumped about this project.:D
Thanks heres a pic of it |
RE: Q40 Racer!
Pretty sexy set up. I'm looking forward to hearing how much you like it.
RE: Q40 Racer!
ORIGINAL: smoknrv4 Freaking fast did a thread on the 46VX-DF, (which I have saved in my subscribed threads)...but this is the VR-DF, so I would imagine the performance is lacking a little in comparison, but I'm wondering how close it is with prop sizes and type of header pipe set-up etc...Freaking Fast could you maybe shed some light on this? I'm really pumped about this project.:D Thanks heres a pic of it this one sure brings back the memories. |
RE: Q40 Racer!
have u run the engine yet?
RE: Q40 Racer!
No I haven't ran it yet, need some exhuast parts still.
RE: Q40 Racer!
Looks like fun.
RE: Q40 Racer!
Nice looking plane good luck with it!
RE: Q40 Racer!
1 Attachment(s)
here are the pics i promised, these are of the updated rotor and rotorpin and a couple of shots of the exhaust port and crank pin this is the ducted fan version with max exhaust duration. rpm range is 2k-25k and true abc sleeve setup
RE: Q40 Racer!
Sure you can't shoehorn that OPS .65 in there?
RE: Q40 Racer!
ORIGINAL: MJD Sure you can't shoehorn that OPS .65 in there? I had a look already but its just too big. darnnit.[:@] |
RE: Q40 Racer!
Thanks for the pics Ifinney...I wonder what the advantage is with the mods to the rotor and backplate? I'll have to take mine apart to see what it is.
I'm almost finished building the motor mount for it out of billet AL, kind of a custom jobby to fit it in the plane.:eek: |
RE: Q40 Racer!
the main issue was longevity, some of the early pins wore quickly, and the rotors as well, its not such a big issue in racing as the engine runtime is small, but with sport flyers and ducted fan users it becomes a bigger issue, there were reports of the set screw coming loose and the the pin and assembly wad up the internals of the engine...
RE: Q40 Racer!
ORIGINAL: lfinney the main issue was longevity, some of the early pins wore quickly, and the rotors as well, its not such a big issue in racing as the engine runtime is small, but with sport flyers and ducted fan users it becomes a bigger issue, there were reports of the set screw coming loose and the the pin and assembly wad up the internals of the engine... Good to know.;) |
RE: Q40 Racer!
1 Attachment(s)
Ok moven' right along....did a little modifying to fit the 46 VRDF, made a billet mount for it and some standoffs to allow space for the intake, so I had to remove the original firewall and make a new one about half an inch back farther to allow space for intake. I also tapped a couple of holes on the front of the beams to tie them in to the nose with some ply.
RE: Q40 Racer!
thats looking good. very nice work on the motor mount :D
RE: Q40 Racer!
ORIGINAL: robbyvaughn9 thats looking good. very nice work on the motor mount :D |
