lanier shrike info please
Picked up a VERY nice kit built shrike. Could use some help with the correct cg location as well as recommended throws for high/low rates.. Plane is like new! Want to make sure I get this right. Thanks
If you don;t hear back sooner, I have a plan set at home and can check this out later.
would be very helpful. thank you
OK.. from the plans, the CG "range" is shown at 5-7/8" from the LE at the fuse.
Aileron low +- 1/2", high "all you can get" Elevator low +- 3/4", high "all you can get" |
Shrike Kit
skinut : Glad to help, if I can.
The Lanier Shrike and I have a history of about eight years now. Several years ago I built a Shrike from scratch. Took several months, but was a good project, and I learned a lot!! I put a JEN 57 engine in it and she flew like a bird on fire! Loved it. Then after a season or two, after having flown her several more times... One day at about 100mph the radio stopped responding and she flew through a tree and went into about 300 pieces!! That was two years ago. I am now in the process of building the same as a kit I purchased (someone had it in their basement, and were kind enough to sell it to me). The reason I'm responding is because depending on the engine you want to use, the CG and travel of ailerons and elevator are kind of adjustable to what you're going to use, as a whole, in the set-up. The numbers from the plans are a good starting point. Play with it! I think you'll love the Shrike. Just check it over carefully before each flight!! As I'm putting this plane together, this time, I wondering if I should go with a 10oz. - or - 12 oz. tank. Won't really matter I guess. Have fun!! |
