RCU Forums
-   Extreme Speed Prop Planes (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/)
-   -   electric diamond dust (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/11677614-electric-diamond-dust.html)
rcflyer45 04-18-2020 06:32 PM
Hello anyone flying an electric diamond dust? What equipment did u use ?
Chris
c/f 04-20-2020 06:21 PM
I did, unsupported covering on leading edge kept me from going past 140MPH and then covering compression would induce unstable wing warping control. beyond that it was fun to a point.
I would gear up for a battery weight of 400g-500g which will max you out to around 1000W-1500W setup, I geared up for 7" props to get enough pitch options as I went forward with development.
FWIW a box stock EXTREME FLIGHT OUTLAW, will get you 150MPH for a $500 investment as a benchmark, I fly a converetd EF nitro version to electric and in the 170MPH range at 2500W with a 700g battery.
.02
rcflyer45 04-30-2020 05:14 PM
.02
Ok well I got mine to go 175mph with a neu 1115 1y on 5cells spinning a 6x5.5 prop it's a blast to fly !! Sounds cool also
