Help - need more speed
Hi folks,
This should be a simple question to you real speed freaks, I want to extract some more speed from my corex delta without changing engine/muffler. It’s a simple corex delta powered by an Enya 30 heli engine, turning a 9x6 prop running 5% nitro. Whats the best approach to up the speed based on using other props and maybe upping the nitro? If it makes any difference, I have used much higher nitro in the same engine when it was in the heli. Cheers Chris http://www.hangarspace.co.uk |
Chris,
Try an 8x8 or 8x9 prop. Just remember the trade off for speed is less thrust when you are going slow. Mark M. |
Pitch = speed is the bottom line. A 9x6 won't get you the most speed. I echo Mark's comments on reccomended props 8 or 9 pitch with less diameter. Nitro won't give you r's. It usually lets you turn a larger load (i.e. pitch). You can give it a try. 15 or 20% certainly is not a problem.
Michael |
Website, props etc
Very nice website Chris!
Mark Mallory is one of the gurus. Sounds like good advice to me, give it a try. |
