Sound R.E. 15-25 engine and source
I'm contemplating my own design sport/speed model and am looking for input on a good (and economical) rear exhaust engine in the .15-.25 size range. Not looking for the ultimate in high performance and price, just something solid that I can set up on a tuned pipe and rip around for kicks. [8D] As I progress I'll share some pics etc.
RE: Sound R.E. 15-25 engine and source
Hey there....welcome!
try this thread for starters http://www.rcuniverse.com/forum/Engi...2255693/tm.htm For RE, there are older K&B 3.5 engines out there..... some older OS 25 DF engines too. Sometimes can be had for a bargan. Very good engines.. both respond very well to pipes. NovaRossi 09-20 is outstanding. Currently available Irvine XR-15 is a real nice engine Rossi use to have both .15 and .21 size engines - look around a bit. Older Cox/K&B/Ron Young .15 engines are out there. Excellent power... use to use these for QM15 racing. Check around with the Free-Flight guys and some of the older pylon guys. There are a few Nelson .15 engines still out there. Not throttle capable, but very powerful. MVVS has a a few engines in the size range....they use to make a RE years ago...... not sure if its still available. The Jett FIRE .25-35 engines are the top of the list in performance. $260 roughly... plus pipe. Can be tuned to exactly the rpm/prop you desire. A few import engines available from SC and SY. Check with the FF guys for excellent sources for any of these size engines.... I hope this is helpful Bob |
ORIGINAL: bob27s NovaRossi 09-20 is outstanding. Currently available Bob If so, under what circumstances? Pipe? Prop? Fuel? |
Cox Conquest .15 or Nelson .15, just find yourself a good set of ear plugs :)
Do a little looking, and put out a wanted add. Quite a few of these are laying around in the old time pylon guys drawers looking for a home. They probably have a few special props for them also set for the right rpm. The Nelson is an absolute screamer, but the cox is no slouch either. |
RB...
I had the opportunity a few weeks ago. Apparently the new US distributor for the Nova engines is supplying them with the UltraThrust mufflers. Made for a nice combo. 10% Byron fuel........ tested with a 10x6 prop. Came up only about 3-400 rpm short of my SJ-50... very impressive. Only had a small amount of time with it. I believe Dub had an opportunity to play with one not long ago too. |
The MVVS 15 can be changed from SE to RE by rotating the cyl. The R/C carb. is too restrictive look for a C/l ventura.
