Cheap,fast and looks cool thread!
I figured I would throw in a couple that meets the criteria:
Global ME-109/46AX= ALOT of fun $89.00 airplane GP Combat Corsair/25FX= Fast and fun $99.00 airplane Please add yours, this really helps alot of people wanting to try out the speed aspect! |
RE: Cheap,fast and looks cool thread!
cheap and fast. hmmm. well im not sure those two can go together. But im all ears! i guess it depends on deffintion of fast. that 46ax is a good turner for the price though.
I was recently looking at trying something in the speed category. Decided on a Shrike 40. $59.99 for the kit. Add engine and radio thats lying around in a seldom used plane, and thats one cheap entry into this field.
I am probably going to be slammed for posting kits but I am glutton for punishment and I like to build, :)
Diamond Dust $64.95 KIT Wing Span: 34.5" Wing Area: 575 sq in Wing Loading: 9 oz / sq ft Weight: 2.25 -2.5 lbs Engine Req: .25-.40 2 cycle Sig Kougar Mark II Kit $79.99 Wingspan: 50" Wing Area: 540sq.in. Length: 45.5" Weight: 5.5 - 6 lbs. Airfoil: Fully-Symmetrical, Low-Wing Wing Loading: 22 oz/sq ft Engine: .40-.50 (2-stroke) Sig Kobra $62.99 Wingspan: 45" Wing Area: 390 sq in Wing Loading: 19 oz/sq ft Fuselage Length: 39.3" Weight: 3.3 lbs Airfoil: Fully-Symmetrical, Low-Wing Sig Wonder Kit .09-.19,37.5" $36.99 Wingspan: 37.5" Wing Loading: 11-16 oz/sq ft Airfoil: Fully-Symmetrical, High-Wing Wing Area: 338 sq. in. Weight: 26-38 oz. |
one more I forgot,
kangke monocoupe giant scale and a G26 two words super fast...[sm=wink.gif] |
Now you are talking! That is the fastest airplane I have had! The fastest SOLD that is!
ORIGINAL: NCBrit I was recently looking at trying something in the speed category. Decided on a Shrike 40. $59.99 for the kit. Add engine and radio thats lying around in a seldom used plane, and thats one cheap entry into this field. |
how hard are the shrikes to build, I'm asking for a friend that has never built anything and wants something small, fast, non-squirlly, low cost category.
shrike 40 - shrike 10 |
ORIGINAL: gizmo8012 how hard are the shrikes to build, I'm asking for a friend that has never built anything and wants something small, fast, non-squirlly, low cost category. shrike 40 - shrike 10 |
It's a shame that Kangke no longer makes the F3D. It certainly is fast and looks good. I understand that a new one is on the way. Cheap? Well, just maybe:D
I agree with Mike, they're an easy build. On the 10 size, in addition to replacing the spars, if you're "upsizing" the engine, it's a good idea to move the firewall back 1/2" or so. This helps get the balance right. The two parts of the Shrike build I didn't like were dealing with the modified exhaust path (my fault, I used a rear exhaust engine), and covering it (the joint between the wing and fuse is a major pain to get right). If one wants something cheap and fast that looks the part, the Shrike is a great candidate. Heck, if I keep posting about it I may just have to build another. :D
But when the Shrike is done right, it is worth all the hassle. Just buck up the spars. I have seen them buckle under not a lot of load, and if you do upsize the engine, loads are going to be a real factor.
John |
But when the Shrike is done right, it is worth all the hassle. Just buck up the spars. I have seen them buckle under not a lot of load, and if you do upsize the engine, loads are going to be a real factor. John I may be ordering one for myself too after all this talk about it. ;) |
I am getting ready to build a new one. I am going to just replace the balsa spar with carbon fibre. I have heard that a lot of people use hardwood, but since I am going to be putting an OS 32 on a 10 size, I think that the greater strength is in order.
John |
I will have to thank ol' lear31 for starting this thread so I will be interested in another plane. :D
I had a blast with my Shrike 10. It had an OS25FX and it screamed! As far as covering, I got tired of trying to get the wrinkles out of the area where the fuse and wing meet. I just put some trim tape in this area and then covered up to the edge of it. The rest of the airplane was easy to cover. Go ahead and build one gismo, that way I can buy it from you!
10 - 4 rubber ducky
[sm=lol.gif] |
your gonna want a sig kougar when you see mine, I'll be bringing it out soon.
OS .50sx - 159 sig kougar mkII - 80 12oz tank full of green turn and burn excitement - priceless!!! |
Best bang for the buck has got to be the diamond dust ( http://www.diamonddustrc.com ). that little wing with a TT.36 moose can muffler, and 35%nitro with some practice and tuning is a 150mph plane.
http://www.diamonddustrc.com/diamondd.jpg Ive seen some claimes with the Jett.50 of 200mph, but realist speed with a .46 and 15% nitro is still 120-140mph. |
1 Attachment(s)
ORIGINAL: gizmo8012 how hard are the shrikes to build, I'm asking for a friend that has never built anything and wants something small, fast, non-squirlly, low cost category. shrike 40 - shrike 10 Gizmo, If your freind has never built a kit before point him in the direction of a SIG Wonder. ...Not as fast as a shrike yet still quick and very agile and no bad habbits. From a building standpoint the SIG is far better! It has Excellent plans and Photo Illustrated Instructions. A .25FX fits in the nose just fine and CG is easy to obtain by moving battery aft or mounting servos under the stab. (hint ) built it so the Stab bolts onto the fuse ( wing mount blocks have plenty of room) and skip the access hatch on the bottom of the fuse. Also the Wonder is a complete kit, it has all the hardware he will need ( hinges, torque rods, motor mount, horns clevises, ect.) while the Shrike is a box of wood plans and type written instructions. after flying the snot out of the Wonder then go for a Shrike! Just my .02 Bob Brother # 104 or 105 |
